Main : Mechanical : Engine Worked Head 1a
[<   Previous  2459  2460  2461  2462  2463  2464  2465  Next   >]
Worked Head 1a
Worked Head 1aPopular
SubmittermatbighatMore Photos from matbighat   Last Update2005/7/5 7:21    Tell a friendTell a friend
Hits3471  Comments9    0.00 (0 votes)0.00 (0 votes)
Wowser
Dodgeman
Posted: 2005/7/5 13:32  Updated: 2005/7/5 13:32
 Re: Worked Head 1a
The valve guides are a bit short, but it should flow well.
MLS
Posted: 2005/7/5 13:45  Updated: 2005/7/5 13:45
 Re: Worked Head 1a
Actually I think I can see one problem with the porting job, the inlet ports have been polished too much.
It is best to leave a sllight roughness in the inlet port as it creates an "air lining" on the port walls that reduces friction when the air/fuel mix flows through it.
Other than that, good job!!
kululadotgroen
Posted: 2007/9/27 7:46  Updated: 2007/9/27 7:46
 Re: Worked Head 1a
Agreed, my dad used to polish it to a shine, and then he would use a drill with a piece of round bar split down the middle. In this groove he would put a very rough piece of sand paper. He would then spin the drill up in short bursts, while pushing this "flap wheel" down the port, creating roughness, and almost grooves in the port walls. He said this created the air lining, but also introduced swirl in the mixture, so that you would get a more even spread of the mixture in the chamber...
1200GXman
Posted: 2007/9/27 8:01  Updated: 2007/9/27 8:01
 Re: Worked Head 1a
@kulula
Damn good idea that your dad used.I will keep that sand paper trick in mind for when I plan to do something to my cylinder head.
Swirl is always good on the intake.
rally1200
 Re: Worked Head 1a
Nice manafold gasket. Where can i get one.
matbighat
Posted: 2005/7/5 21:27  Updated: 2005/7/5 21:27
 Re: Worked Head 1a
I believe it's a standard GX gasket with the intake sealing rings removed.
2332owner
Posted: 2007/9/27 1:57  Updated: 2007/9/27 1:57
 Re: Worked Head 1a
Looks like the Tomei gasket. Sunny_coupe110 sells 'em.
benny
Posted: 2007/9/27 2:11  Updated: 2007/9/27 2:11
 Re: Worked Head 1a
Nice one Matt...
1200GXman
Posted: 2007/9/27 6:46  Updated: 2007/9/27 6:46
 Re: Worked Head 1a
Is this a GX head?
Please give us the specs what you did and are planning to do further down the road.
Valve sizes,the cc of each chamber,etc.
