Main : Mechanical : Engine a13 race engine ports
[<   Previous  2829  2830  2831  2832  2833  2834  2835  Next   >]
a13 race engine portsPopular
Submitterda-feralMore Photos from da-feral   Last Update2002/12/19 23:11    Tell a friendTell a friend
Hits7730  Comments11    0.00 (0 votes)0.00 (0 votes)
Here is look in the ports note flow bench spring on exhaust valve
da-feral
Posted: 2002/12/29 5:55  Updated: 2002/12/29 5:55
 Re: a13 race engine ports
It has awesome port area and flow for 1298 cc!!! Exhausts flow about 80% of the inlet ports as well surprisingly. I think it would work very well on an A14 - A15 cranked with 79mm bore
Cheers
Feral Errol
dattoman_1000
Posted: 2002/12/20 10:30  Updated: 2002/12/20 10:30
wow they are actually bigger than mine
D
Posted: 2003/2/24 23:53  Updated: 2003/2/24 23:53
From: under the Firmament LOL no twiglight effect BS
Is it possible to go higher with the exhaust ports or are there other consequences like waterjackets.
tsillay
Posted: 2003/2/25 0:25  Updated: 2003/2/25 0:25
Nice!
I have seen them higher, but you run into the spring platfroms. These need to get moved up and you need longer valves..Then the rockers have to be spaced up, then you make up duralumin pushrods with chevy ends on them
Then you move the mounting bolts for the manifold and move the whole damn manifold up too
It's all getting a bit silly about this time...
D
Posted: 2003/2/25 1:27  Updated: 2003/2/25 1:27
Can you just d port the top to get a the same square port but with round top?
Datsun100ATurbo
Posted: 2003/2/25 6:37  Updated: 2003/2/25 6:37
You can D-port the top of the head but don
D
Posted: 2003/2/25 14:13  Updated: 2003/2/25 14:13
Thats it, time to mangle an old a12 head to see how far to go. Since Im getting a custom exhaust header Id like to do it. However my dream setup, I dont know the term (someone educate me) would b alloy tubes welded into the head to act as an inlet manifold too (ala peripheral port rotary) and same for exhausts.
Datsun100ATurbo
Posted: 2003/2/25 14:28  Updated: 2003/2/25 14:28
I put up a couple of pictures in the photosection under engine where you can see how far you can go. It doesn
D
Posted: 2003/2/26 0:36  Updated: 2003/2/26 0:36
Itd b great to get an inlet gasket made up of this head so all of us know how far to go with our proting first off.
Hey Feral you could make some money from this
tsillay
Posted: 2003/2/26 1:39  Updated: 2003/2/26 1:39
mmm, this'll be welded already wont it?
