Main : Mechanical : Engine A14 Side-draft
[<   Previous  2827  2828  2829  2830  2831  2832  2833  Next   >]
A14 Side-draft
A14 Side-draftPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2003/1/19 7:51    Tell a friendTell a friend
Hits14938  Comments5    0.00 (0 votes)0.00 (0 votes)
stock dual-carb setup
Posted: 2022/4/30 21:43  Updated: 2022/4/30 21:43
 Re: A14 Side-draft
jaimecidpedro
Posted: 2003/1/26 10:02  Updated: 2003/1/26 10:02
 Re: A14 Side-draft
Is the cylinder heads with air pump systems any diferent from this cyl head, this one looks much cleaner than my air pump cyl head. The polution air valve goes to the cyl head, I am all confused now, I got to see my engine.
Jaime
racer135
Posted: 2015/5/30 2:36  Updated: 2019/10/13 0:38
 Re: A14 Side-draft
This is either an A12GX competition setup or A12GX with flat top piston chambers fitted. That's why it doesn't have lots of busy plumbing. Also flat tops and the damper screw tops are flat too.
Posted: 2015/5/31 2:25  Updated: 2015/5/31 2:25
 Re: A14 Side-draft
Yes, is does look like an A12, and A12T carbs without the Idle Mixture Control parts.
Posted: 2015/5/31 2:42  Updated: 2015/5/31 2:42
 Re: A14 Side-draft
Yes ... for both A12 and A14 there are:
* Head without air passage
* Head with air passage for IAS
* Head with air passage for Air Pump
Head with air passage requires a 3-bolt or 4-bolt Thermostat Housing
