Main : Mechanical : Brakes Vacuum Pump - Brakes
[<   Previous  277  278  279  280  281  282  283  Next   >]
Vacuum Pump - BrakesPopular
SubmitterDTWMore Photos from DTW   Last Update2005/8/17 4:33    Tell a friendTell a friend
Hits5200  Comments6    0.00 (0 votes)0.00 (0 votes)
Car runs a VH44 remote booster under the dash which feeds from a 4 litre vacuum tank behind passenger seat (not in picture). Pump (bottom left of picture) evacuates the tank giving boosted brakes (front only). Turn the pump off...tank returns to normal pressure...and then brakes are un-boosted. Pump runs via a pressure switch when it's turned on. Solved a problem of minimal vacuum at manifold. Maybe not the easiest method but it works well.
Dats-hot
Posted: 2005/8/21 2:52  Updated: 2005/8/21 2:52
 Re: Vacuum Pump - Brakes
Electric vacuum pump? Man, that sucks.
Well, someone had to say it.
rally-a-coupe
Posted: 2005/8/21 8:43  Updated: 2005/8/21 8:43
thats what i am running in my subaru and diesel alternator works brillantly constant pedel feel
ang94541
Posted: 2005/8/18 9:20  Updated: 2005/8/18 9:20
I dig the way your fuel pump is mounted. Very cool.
D
Posted: 2005/8/20 10:14  Updated: 2005/8/20 10:14
From: under the Firmament LOL no twiglight effect BS
Feral I always thought I could do something with those type of alternators. Now you`ve saved me some sleep
feral
Posted: 2005/8/18 0:59  Updated: 2005/8/18 0:59
My solution for this is to fit a diesel alternator/vacuum pump combination. These alternators have a vacuum pump attached to the rear of the shaft.
DTW
Posted: 2005/8/18 1:54  Updated: 2005/8/18 1:54
Feral.......your suggestion is a far better option than what I did for anyone looking for a remote vacuum source if you have a lumpy cam giving minimal vacuum at the manifold. The way I did it was rather costly with the price of the pump ($800). I only found out about the diesel alternator/vacuum pump setup after this was installed. It's in now though so it'll stay.
