Main : Mechanical : Brakes New Vented rear discs
[<   Previous  275  276  277  278  279  280  281  Next   >]
New Vented rear discsPopular
Submitterrally1200More Photos from rally1200   Last Update2006/5/2 14:33    Tell a friendTell a friend
Hits2711  Comments3    0.00 (0 votes)0.00 (0 votes)
Just upgrade to new vented rear discs, seem much better than my commodore setup.
dattoman_1000
Posted: 2006/5/3 13:48  Updated: 2006/5/3 13:48
 Re: New Vented rear discs
n't be shy
Specs man
1200coupe
Posted: 2006/5/3 14:10  Updated: 2006/5/3 14:10
Looks like a good conversion.
Just out of interest can you post a pic of the caliper mounts from behind
rally1200
Posted: 2006/5/3 14:47  Updated: 2006/5/3 14:47
Rotors are from the front of a Suzuki Swift 1990. Wheel studs are the same and they are 231mm so fit in 13" rims ok.
I have used the callipers as well 47mm piston so with my pedal box setup and hydraulic hand brake, things are working much better.
I have just change over to a full sprinter rear setup with sprinter axels. So i have modified a standard sprinter disc brake caliper braket. But this conversion would also work on a H165 setup.
