[< Previous 2263 2264 2265 2266 2267 2268 2269 Next >]
Chickenhawk's engine
dimlight65 2002/7/3 19:08 Tell a friend
13147 9 9.00 (2 votes)
| NAPS-Z two liter with cam, Weber 38/38 synchronous carb, and custom header built by yours truly. |
| Poster |
Thread |
| jaimecidpedro |
Posted: 2002/7/4 2:10 Updated: 2002/7/4 2:10 |
No life (a.k.a. DattoMaster)   Joined: 2001/8/2 From: Posts: 1358 |
 Re: Chickenhawk What is the cover you have over the air filter,is it to keep the filter cleaner on dusty roads? Does it affect the performance? If not,I may need one,there is a lot of dust around here.If I clean the engine,in a week it is full of dust. Jaime
| Poster |
Thread |
| dimlight65 |
Posted: 2002/7/4 4:30 Updated: 2002/7/4 4:30 |
No life (a.k.a. DattoMaster)   Joined: 2001/2/7 From: Fort Worth, Texas, USA Posts: 1003 |
 Re: Chickenhawk And she's wicked fast too. No, the engine swap wasn't too difficult. It came out of a 1980 HL-510 and never even hit the ground. I lifted it out and dropped it in the 1200, welded up some engine mounts, figured out a tranny mount, and started wiring and plumbing. You may notice that the radiator is moved forward a bit for clearance. That cover over the carb IS the air filter. It's made by a company called Piper Cross, out of England I believe. I wanted it for the direct inflow straight in to the carb. There is a 300ZX turbo hood scoop right above it. As for the strut bar, this one was done differently than the way I do it now. This one is made from a suspension pushrod off of a Swift DB-6 formula Continental that I cut in half and welded into a piece of conduit. There are Heim joints at both ends for adjustment. Way overkill. What I do now is cut a piece of conduit to the right length, mash the ends flat, drill holes and bolt her up. Cheap, easy and works just as well.
| Poster |
Thread |
| jaimecidpedro |
Posted: 2002/7/5 5:39 Updated: 2002/7/5 5:39 |
 Re: Chickenhawk That is cool, I will make my own tower bar like that,I will show it once done. A pipe ,flaten both ends and bolt it in,previous "looks" red or yellow paint. Eventually I will swap an engine,I am between the CA18,the SR20,or a 13B,but later on,I want to enjoy my A15,so I am planning a single (or dual,if I can get around the brake booster problem) DCOE. Nice job! Jaime
| Poster |
Thread |
| woodydat |
Posted: 2004/5/28 22:16 Updated: 2004/5/28 22:16 |
Home away from home   Joined: 2004/1/29 From: Posts: 961 |
 Re: Chickenhawk hey sorry bout bringing an old post up but what power figures is that thing pumping..? have u had it dyno'd yet? im keen to put a L20b in a 1200 ute.. and id love to have a cross flow head ( if i could find the bits id like to use a naps z head) do's any body now if getting parts 4 the naps z is hard?
| Poster |
Thread |
| tens_and_twenties |
Posted: 2007/9/1 4:31 Updated: 2007/9/1 4:31 |
No life (a.k.a. DattoMaster)   Joined: 2001/10/15 From: Fort Worth, Texas, USA Posts: 1304 |
 Re: Chickenhawk Quote: hey sorry bout bringing an old post up but what power figures is that thing pumping..? Never had it on a proper chassis dyno, but figure at least 150hp and around 140 ft.lb of torque. It has a very stout cam, but makes GOBS of torque. Quote: do's any body now if getting parts 4 the naps z is hard Depends on where you are. Here in the US it's easy, elsewhere maybe not...
| Poster |
Thread |
| jaimecidpedro |
Posted: 2002/7/4 2:04 Updated: 2002/7/4 2:04 |
 Re: Chickenhawk Looks nice. It does not look too big,was it an easy instalation? I know it was not EASY,but I mean,any big problems or was it a workable swap? About your tower bar,is that easy to make? just a bar with eyes that fit a bolt on the tower? or is it have to be adjustable? Jaime
| Poster |
Thread |
| danielblues |
Posted: 2002/7/3 22:59 Updated: 2002/7/3 22:59 |
Webmaster   Joined: 1998/12/4 From: Lisbon - Portugal Posts: 487 |
 Re: Chickenhawk And we have our first upload! COOL! Nice one too!  daniel
