Main : Mechanical : Engine camshaft lobe
[<   Previous  2445  2446  2447  2448  2449  2450  2451  Next   >]
camshaft lobe
camshaft lobePopular
SubmitterTyrieMore Photos from Tyrie   Last Update2006/2/3 10:12    Tell a friendTell a friend
Hits3400  Comments10    0.00 (0 votes)0.00 (0 votes)
doesnt look too healthy...
Tyrie
Posted: 2006/2/3 10:17  Updated: 2006/2/3 10:17
 Re: camshaft lobe
Any opinions as to what causes the pitting? I figured its where more metal has been added to give more lift and duration, only it was a porous weld??
ps. I've been told its a lumpy cam, it might not be
dattodevil
Posted: 2006/2/3 10:22  Updated: 2006/2/3 10:22
 Re: camshaft lobe
It's gone through the hardening, probably just due to wear. May have not been run in correctly if it's not that old, or you are getting coil bind on the valve springs. At a guess
Tyrie
Posted: 2006/2/3 10:31  Updated: 2006/2/3 10:31
 Re: camshaft lobe
yeah I'd say its pretty old, and it has double valve springs... nothing to worry about though?
dattodevil
Posted: 2006/2/3 10:34  Updated: 2006/2/3 10:34
 Re: camshaft lobe
well you would still replace it, but if it's quite old, i wouldn't be too worried about it current condition, just check clearances when you install a new camsaft and run it in correctly.
Lemonhead
Posted: 2006/2/3 11:36  Updated: 2006/2/3 11:36
 Re: camshaft lobe
Mate... to me that porousity if ever I've seen it! Not only that whats that sus blue mark on the cam lobe.
If it were me that cam would be in the wheelie bin by now, just replace it now while the engine is pulled down to this state.
In my opinion its only going to bite you in arse later (how much later...not very much later)
benddatsun
Posted: 2006/2/3 14:23  Updated: 2006/2/3 14:23
 Re: camshaft lobe
I agree with lemonhead get a new camshaft.
BACKFIRE
Posted: 2006/2/3 19:11  Updated: 2006/2/3 19:11
 Re: camshaft lobe
I thought you "lumpied" up a cam by removing material from the low side of the lobe rather than welding more material to the high side.
The porous effect is possibly just the average metal under the hardened stuff that you can see has worn off.
My 2 cents would be to replace as this lobe could be on it's last legs.
dattodevil
Posted: 2006/2/4 4:09  Updated: 2006/2/4 4:09
 Re: camshaft lobe
yeah I agree with replacing it, I just wouldn't be too concerned about what caused it as it happens sometimes. Just do all the right checks when you put a new camsaft in.
A14force
Posted: 2006/2/4 5:04  Updated: 2006/2/4 5:04
 Re: camshaft lobe
You can tell this cam has been ground by the tuning markes where the piece between the lobes has been relieved to allow more material to be removed from the heel.
Throw it as far away as you can, it's carnal knowledged.
bobs1200
Posted: 2006/2/4 9:02  Updated: 2006/2/4 9:02
 Re: camshaft lobe
make sure you throw it away and also replace the valve lifters or you will damage your new cam
Bob
Posted: 2006/2/4 17:38  Updated: 2006/2/4 17:38
 Re: camshaft lobe
Old? What's age got to do with it? My camshaft is 33 years old and not worn out.
Remember that a new camshaft must be properly run in. See your cam grinder's instructions, or a repair manual. The typical advice is this:Quote:
You MUST NOT let a newly fitted cam run at idle speed for the first 20 minutes of operation. Always keep the rpms up at about 2000 during this period.
Dats-hot
Posted: 2006/2/4 21:16  Updated: 2006/2/4 21:16
 Re: camshaft lobe
Age shall not weary them,
nor the years condemn,
but at the going down of the sun,
you should remember this.
You should send this cam to a far far better place, before it does itself a real injury, & you find yourself removing the engine yet again so as to replace this part that should have been replaced right now.
It looks like you have cought this one just in time.
Tyrie
Posted: 2006/2/5 8:19  Updated: 2006/2/5 8:19
 Re: camshaft lobe
thanks guys you've changed my mind I'm now going to put the 5spd in with the a12 for now and replace the cam if not rebuild the a14.
can anyone suggest a good cam/brand of cam to suit a worked a14 on webers?
oh and for anyone planning a t50 conversion, make sure you enlargen the tunnel before putting it in. The damn thing is so long its hard to insert and remove when attached to an engine, and now i gotta pull it again and attack the tunnel... not happy
