Main : Members : Ianey kb10 coil rear suspension
[<   Previous  29  30  31  32  33  34  35  Next   >]
kb10 coil rear suspensionPopular
SubmitterIaneyMore Photos from Ianey   Last Update2006/3/26 3:54    Tell a friendTell a friend
Hits2975  Comments7    0.00 (0 votes)0.00 (0 votes)
for a thread
Ianey
Posted: 2006/3/26 3:55  Updated: 2006/3/26 3:55
 Re: kb10 coil rear suspension
for this thread
sidedraught
Posted: 2006/3/26 5:07  Updated: 2006/3/26 5:07
Whos car is this in?
Ianey
Posted: 2006/3/26 5:14  Updated: 2006/3/26 5:14
Hey Andy,
The pictures are from the b10 yahoo group website. Go to photos and click on bennys thou. You will have to register, etc, but it is worth it. This guys car should be a killer when finished.
Ian
naman
Posted: 2006/3/26 6:32  Updated: 2006/3/26 6:32
Would this will help to smooth ride in b110 also? The problem at the back, hard bumping.. but the leaf spring maybe stronger to bring somethin heavy.. my front suspension is good enough.. custom adjustable and hondacivic springs
I like to be more lower from this..
rb20
Posted: 2006/3/26 8:38  Updated: 2006/3/26 8:38
wat size wheels are you running on the black 1200 i realy like the way it sits
naman
Posted: 2006/3/26 9:00  Updated: 2006/3/26 9:00
It's 13, 175/50 X 13 front, 185/60 X 13 rear.. Like to lower 1 or 2 inch at rear..
Ianey
Posted: 2006/3/26 9:18  Updated: 2006/3/26 9:18
How about softer shock absorbers to smooth out the harshness and lowering blocks?
rb20
Posted: 2006/3/26 9:30  Updated: 2006/3/26 9:30
they look bigger than 13" but i guess that is because it sits so low and the tyers are low profile. I have 13 inch but i do not think i could get my car that low because mine are 8" with a deep dish off set
naman
Posted: 2006/3/26 11:37  Updated: 2006/3/26 11:37
Now I use soft abs' but the harder as i use before (tokiko gas) may better in cornering.. but the gas not suitable for carrying people. Very hard when drive trough the bumper. Love them at the corner.. I'm thinkin about there're diffrent between leaf spring and coil spring which coils can be more comfortable.. but the leaf more stronger.. Am i right..?
I'm 3 inch lowering block at rear now.. Worry to use 5 inch.. is 5' inch sefety to use..?
Tyrie
Posted: 2006/3/27 2:11  Updated: 2006/3/27 2:11
I thought 3" would cause problems. Surely 5" would leave the shock mounting point scraping on the ground.
naman
Posted: 2006/3/27 4:03  Updated: 2006/3/27 4:03
Till now i use with no prob. , make a hole at the point..
just one problem.. can't turn slow at everycorner... ha.. ha....
