Main : Mechanical : Engine Torque & rpm calculated from dyno run
[<   Previous  2424  2425  2426  2427  2428  2429  2430  Next   >]
Torque & rpm calculated from dyno runPopular
SubmitterGrunterhunterMore Photos from Grunterhunter   Last Update2006/4/6 6:57    Tell a friendTell a friend
Hits2966  Comments4    0.00 (0 votes)0.00 (0 votes)
85% of peak torque from 2500 to 5500
Grunterhunter
Posted: 2006/4/6 7:01  Updated: 2006/4/6 7:01
 Re: Torque & rpm calculated from dyno run
Oh yeah... torque is at the treads in lb/ft, power is rwhp. the torque figure is derived from the hp figure, so presumably that takes into account the final drive ratio (4.11).
Posted: 2006/4/7 3:57  Updated: 2006/4/7 3:57
On the chart the torque does not take into account the diff ratio, otherwise it would be 4.11 times more torque. As far as I've seen, the RPM is always measured at the engine.
At 5252 rpm, HP and lb/ft are identical. But then the transmission gears multiply torque (except 4th gear 1:1) and then the differential multiplies it more. Finally, the tire size has something to do with it (larger tires make for less torque).
Grunterhunter
Posted: 2006/4/13 11:57  Updated: 2006/4/13 11:57
Yup, I think we are on the same page here. I have just done the calcs from the acceleration figures I recorded and it seems to agree with the dyno figures pretty well..... if i can find the damn thread.
Posted: 2016/9/14 0:19  Updated: 2016/9/14 0:19
Max 71.9 HP at the wheels
This may be the thread: calculate rwkW without a dyno?
