Main : Mechanical : Engine A-15
[<   Previous  2390  2391  2392  2393  2394  2395  2396  Next   >]
A-15
A-15Popular
SubmitterGrunterhunterMore Photos from Grunterhunter   Last Update2006/4/3 11:21    Tell a friendTell a friend
Hits3139  Comments5    0.00 (0 votes)0.00 (0 votes)
32/36, mild cam, extractors, polished head. All that for about 10 hp at the fly  :(
Grunterhunter
Posted: 2006/4/3 11:25  Updated: 2006/4/3 11:25
 Re: A-15
Sorry about the photo size- it took 10 attempts to get it into the album.
I hopped onto the end of an XR6 club dyno day for a bit of light entertainment. Surprisingly, the ford boys had a lot of respect for the datto (I think cos the workshop had a 12 sec ute in the carpark)
mad120y
Posted: 2006/4/3 14:54  Updated: 2006/4/3 14:54
 Re: A-15
you had it dynoed before the mods?
If your going off the nissan/datsun figure i can tell you that it is waaaay inflated.
I would say thats decent grunt, bet it goes alright!
Grunterhunter
Posted: 2006/4/4 2:49  Updated: 2006/4/4 2:49
 Re: A-15
Yeah, goes ok, really good torque, well above the stock figure...... But I don't know if its valid. I calculated a torque curve from this power curve using the formula:
(hp*5252)/rpm
And it maxed at 80 lb/ft at the wheels (presumably corrected for diff). this implies well over 100 lb/ft at the flywheel @ 4000 rpm... not all bad news, but I need more torque
matbighat
Posted: 2006/4/4 4:51  Updated: 2006/4/4 4:51
 Re: A-15
for a comp, my a14gx (pretty stock except a too large cam) did 76@6000
dattoman_1000
Posted: 2006/4/4 11:44  Updated: 2006/4/4 11:44
 Re: A-15
Mine on what looks like the same dyno (I think I read Hyperdrive in there in little letters)
Linky Linky
Grunterhunter
Posted: 2006/4/4 12:13  Updated: 2006/4/4 12:13
 Re: A-15
That sounds like a "mine's bigger than yours" moment there Neil
I'd say it was the same place, hyperdrive off alexander drive in the north eastern suburbs. Did you ever get a torque curve from that? Cos that power comes on with a bit of a rush compared to mine..... gearbox breakage????
EDIT: The drop & surge in the curve looks like it is AFR related- same as the one early on in my curve (if you have a magnifyig glass)
