Main : Mechanical : Engine Rocker shaft spacers
[<   Previous  2418  2419  2420  2421  2422  2423  2424  Next   >]
Rocker shaft spacersPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2006/4/30 19:11    Tell a friendTell a friend
Hits3731  Comments8    0.00 (0 votes)0.00 (0 votes)
For high-rpm A-series engines, the spacers replace the stock springs. Apparently they reduce rocker & valve wear that occurs only at high rpm.
stirlingmac
Posted: 2006/5/1 7:45  Updated: 2006/5/1 7:45
 Re: Rocker shaft spacers
To stop the alloy galling I would use some thin bronze washers either end of the alloy spacer, or make the spacers from bronze to start with.
cheater_5
Posted: 2006/5/1 10:44  Updated: 2006/5/1 10:44
SWEET
Just my stupidity showing but why would bronze be best ??
1200coupe
Posted: 2006/5/1 13:03  Updated: 2006/5/1 13:03
stirlingmac,
I actually used bronze thrust washers with my allow rocker spacers. I didnt go into it in the other thread because I was trying to keep my explanations simple. Fitted them wherever a rocker egde came directly in contact with any post edges, I did this just incase but in theory the alloy should be OK because if the rocker to valve stem alignment is right and the oil clearance end floats set properly, Bronze shouldnt be needed. Plus of course it's a little heavier than T6061 - every little bit matters
2332owner
Posted: 2006/5/1 13:15  Updated: 2006/5/1 13:15
So what's your recommended clearance?
1200coupe
Posted: 2006/5/1 13:23  Updated: 2006/5/1 13:23
Set all end floats to 0.003" (hot) to keep everything wet whilst still locating the rocker axis centrally over the centreline of the valve stem.
A14force
Posted: 2006/5/2 7:10  Updated: 2006/5/2 7:10
I thought the idea behind these bushes was to prevent the standard springs from compressing, and bending the pushrods through the rocker arms migrating along the shaft.
cheater_5
Posted: 2006/4/30 21:50  Updated: 2006/4/30 21:50
any dissadvantages? Noise maybe ??
Just interesting to see
1200coupe
Posted: 2006/5/1 4:07  Updated: 2006/5/1 4:07
No dissadvantages with this modification. There is no noticable noise especially considering they are most useful in very high rpm applications.
