Main : Misc : Tech Section a14 auto to manual
[<   Previous  347  348  349  350  351  352  353  Next   >]
a14 auto to manual
a14 auto to manualPopular
SubmitterDatsunSSSMore Photos from DatsunSSS   Last Update2006/7/4 0:45    Tell a friendTell a friend
Hits3153  Comments4    0.00 (0 votes)0.00 (0 votes)
my a12 flywheell doesnt fit the  a14 crankshaft, why?????
everybody does thid transformation , why i cant????
Cable_Tie
Posted: 2006/7/4 3:42  Updated: 2006/7/4 3:42
 Re: a14 auto to manual
The holes are not evenly spaced. Sit the flywheel on the crank and rotate it around slowly. You will see when it matches all holes at once.
DatsunSSS
Posted: 2006/7/4 3:53  Updated: 2006/7/4 3:53
the holes are ok, but the circle around are not from the same size.
killer1200
Posted: 2006/7/4 4:25  Updated: 2006/7/4 4:25
cable is right the flywheel can only go on one way.
Cable_Tie
Posted: 2006/7/4 4:32  Updated: 2006/7/4 4:32
Just read that it is an auto to manual swap. . . (read things people!)
Check this out:
or this thread:The right is a spacer and comes off with a whack
It caught me out a while back. . .
Gary_P
Posted: 2006/7/4 5:40  Updated: 2006/7/4 5:40
Cable_Tie's got it ritht.
1st, make sure that the spacer for the automatic is off the crank.
2nd, make sure that there is a pilot bushing in the crank.
3rd, rotate flywheel untill all 6 holes line up.
4th, you may want to drill out the 6 holes in the 1200 flywheel just a bit. .5mm should be enough. 1200 flywheel bolts are 9.45mm across the threads. The A14 flywheel bolts are 9.86mm across the threads.
I had the flywheel bolts shear off when a friend was driving the converted rally car during an autocross. Didn't think an A15 with 1200GX head and SU's could survive WOT without even a flywheel... but it did. This car had a lightened 1200 flywheel on a A15. Seemed like the bolts were a bit tight going in. Had the bolts in a bind. After drilling out the flywheel holes everything bolted back together and worked for 2 more seasons of autocross.
DatsunSSS
Posted: 2006/7/5 1:33  Updated: 2006/7/5 1:33
I was looking for the "auto to manual " post but i couldn find it.
Many thanks cable_tie, it was a spacer and not a different crankshaft. lool
i dont have to drill the holes because the bolts from the b210 are from the same size.
thanks to all
americo
