Main : Mechanical : Engine more from Central America
[<   Previous  2387  2388  2389  2390  2391  2392  2393  Next   >]
more from Central AmericaPopular
SubmitterMARCOANTONIOMore Photos from MARCOANTONIO   Last Update2006/7/6 2:19    Tell a friendTell a friend
Hits4384  Comments6    0.00 (0 votes)0.00 (0 votes)
From Costa Rica
B110SSS
Posted: 2006/7/6 10:38  Updated: 2006/7/6 10:38
 Re: more from Central America
I can almost hear the poor little thing groaning under the weight of that monstrosity- go the A series!
matbighat
Posted: 2006/7/6 20:43  Updated: 2006/7/6 20:43
you can use the g16 if you run a stand-alone like that. and remember this is most likely a drag car, so the skewed handling matters little
Coops
Posted: 2006/7/7 3:15  Updated: 2006/7/7 3:15
Not too sure about that.... Check out the adjustable strut tops.
Imagine the understeer..... Turn in... Turn in... TURN IN DAMMIT..... Ah there we go .
mad120y
Posted: 2006/7/7 6:55  Updated: 2006/7/7 6:55
iteresting remote brake setup too.
Seems like they have the same bug we do in Central America. Nice work, even harder to make things fit with SR's in LHD cars.
Also... SR20DE has a fair bit of added weight from things like power steering pump/air con compressor (the bracket alone was like 5kg+) All of which would usually be listed in engine weights.
2QK4U
Posted: 2006/7/6 5:56  Updated: 2006/7/6 5:56
SR20VE NEO 150kw! B120dat this is what i had in mind but these motors would cost. some nice looking headers quad throttles......
could be a SR16VE fwd engine converted to rwd because it has the dizzy removed and has the coil packs......
Posted: 2006/7/6 8:19  Updated: 2006/7/6 8:19
Wow!
