[< Previous 2254 2255 2256 2257 2258 2259 2260 Next >]
Poster |
Thread |
Lotto |
Posted: 2006/9/22 20:40 Updated: 2006/9/22 20:40 |
Just can't stay away   Joined: 2006/2/26 From: Cascais/Portugal Posts: 118 |
 Re: 13b motor mount it
Poster |
Thread |
JDUB |
Posted: 2006/7/9 4:58 Updated: 2006/7/9 4:58 |
Not too shy to talk   Joined: 2005/8/25 From: Palmdale, Ca Posts: 33 |
 Re: 13b motor mount It's all mig welded, as it turns out, I'm going to box it in this weekend.
Poster |
Thread |
JDUB |
Posted: 2006/7/7 4:35 Updated: 2006/7/7 4:35 |
 Re: 13b motor mount I was thinking about boxing in the top and bottom, it would make getting the motor mount off a pain, but might add some more strength. Think that would work?
Poster |
Thread |
killer1200 |
Posted: 2006/7/7 6:26 Updated: 2006/7/7 6:26 |
No life (a.k.a. DattoMaster)   Joined: 2004/5/28 From: Adelaide, South Australia Posts: 1817 |
 Re: 13b motor mount That sould be fine like it is, but because it's a soild mount the bolts will keep loosening from vibration.
That is what you want, but besure that you keep checking them from time to time.
Poster |
Thread |
Wattage |
Posted: 2006/7/7 8:58 Updated: 2006/7/7 8:58 |
Home away from home   Joined: 2002/11/13 From: Portland, Vic Posts: 221 |
 Re: 13b motor mount I'm sure it will be fine for the short term, but I know an engineer would never pass it.
I'd be inclined to have the weight supported from underneath. You may never have problems but it's something to think about. It seems that the piece between the engine and the tube running across the engine bay will be the weakest link, as that steel looks a bit thin there.
Poster |
Thread |
killer1200 |
Posted: 2006/7/7 10:05 Updated: 2006/7/7 10:05 |
 Re: 13b motor mount How did you weld it ? MIG ?
Poster |
Thread |
killer1200 |
Posted: 2006/7/6 19:36 Updated: 2006/7/6 19:36 |
 Re: 13b motor mount Nice job.
That was my idea of mounting as well.
Poster |
Thread |
Wattage |
Posted: 2006/7/7 4:20 Updated: 2006/7/7 4:20 |
 Re: 13b motor mount I don't know what sort of driving you are going to do, but I can see most of the normal driving forces involved will be put through the engine to bar mount if you know what I mean. I'd want to make sure those welds are exceptionaly good, or use some gussets to strengthen the area. I guess I just like to over-engineer things a little.
Apart from that, it looks nice, and it's good to see someone else having a crack at a rotor conversion.
