Main : Mechanical : Engine Methanol Madness
[<   Previous  2368  2369  2370  2371  2372  2373  2374  Next   >]
Methanol Madness
Methanol MadnessPopular
Submitter3RotorMore Photos from 3Rotor   Last Update2006/8/30 20:28    Tell a friendTell a friend
Hits3006  Comments10    0.00 (0 votes)0.00 (0 votes)
the RS2000 motor with turbo and inlet manifold in place
3Rotor
Posted: 2006/8/31 6:43  Updated: 2006/8/31 6:43
 Re: Methanol Madness
that exhaust is actually the 2nd try.
the first one was just a 50mm in the same way out the side there.... it was so damn quite, you can't even hear the car from the stands, while it's screaming down the straight..... well the waste-gate you could hear, clearly but that's just not the same...
TnPshow
Posted: 2006/8/31 12:08  Updated: 2006/8/31 12:08
What's with the strut tower on one side but not the other?
Only goes around the circuit in one direction I take it?
3Rotor
Posted: 2006/8/31 18:46  Updated: 2006/8/31 18:46
yip, only one way....
tappet
Posted: 2006/11/9 6:50  Updated: 2006/11/9 6:50
wow, love the dump pipe..
why is there a tiny rear housing on the turbo???
Tyrie
Posted: 2006/11/9 8:19  Updated: 2006/11/9 8:19
I was reading about turbocharging 4ag/honda motors and they recommended a big compressor housing mated to a small exhaust housing and a massive external wastegate. Works well apparently.
Nice setup, my mate is currently looking to turbocharge his rs2000
Cable_Tie
Posted: 2006/11/9 9:43  Updated: 2006/11/9 9:43
Only change I would make would be to put the intercooler in front of the radiator.
Tyrie
Posted: 2006/11/9 9:46  Updated: 2006/11/9 9:46
is that an oil filter for an air filter?
why not go cosworth twin cam?
3Rotor
Posted: 2006/11/9 12:02  Updated: 2006/11/9 12:02
indeed, the guy who's car it is only had that cooler, and it won't go in front because of the angles of the pipes.... so we had to made the best of it.
thats just a paper air filter...
blofly
Posted: 2006/11/9 12:05  Updated: 2006/11/9 12:05
heh heh it looks like the air filter in my forklift at work!
cheater_5
Posted: 2006/8/30 20:53  Updated: 2006/8/30 20:53
WOW. thats new and original. Good work. man this thing is going to be lethal
datman55
Posted: 2006/8/31 6:11  Updated: 2006/8/31 6:11
Love the Exhaust
