automatic to manual
Not too shy to talk
does anyone know if the datsun 2 door sedan US model with an automatic transmission has the cluth hole for a 5 speed manual transmission or does it have to be made
Posted on: 2006/12/5 17:13
Re: automatic to manual
Not too shy to talk
bump please help someone
Posted on: 2006/12/5 18:01
Clutch hole for a five speed? Is it different from the four speed?
Which hole are you refering to? Is it the one in the firewall for the clutch master cylinder? I guess that a brief examination both inside the engine bay & under the dash would answer that one.
Posted on: 2006/12/5 18:44
Love your Datsun.
Treat it well.
From Burbank, CA
on the later ones where the manual and auto share a chassis...
you may have to open the hole, but it's stamped where the clutch MC would go.
earlier ones, where there is a larger tunnel for the AT, presumably it's not stamped...
Posted on: 2006/12/6 1:05
|||\ 81 KPB310 /|||
From Portland OR. USA
On the US AT models the hole for the clutch master is there but is covered up with a sheet metal cover that is spot welded in place. Takes a cold chisel, hammer, and some patience to uncover. The mounting studs need to be sourced as they are missing.
I used bolts to hold in my clutch master but it takes either 2 people or really long arms to install the clutch master...
Gary
Posted on: 2006/12/6 3:46
Not too shy to talk
hi gary ur help is awesome i really appreciate it. Do u have a messenger i can use to chat with u since i have some other questions thanks though i greatly appreciate it
Posted on: 2006/12/6 9:07
From Alabama, U.S.A.
what year are you trying to convert, cause the 79 , Datsun I converted over like that had the plate just like gary explained ,but did not have the extra bracket under the dash for the clutch pedal. That I had to fabricate myself.
Posted on: 2006/12/6 10:31
From bend oregon
If you are in the oregon area I have all the parts for the conversion from plumming to fly wheel to trans and trans mount and pedal box clutch master for 74-78 b210. maybe works with 79/80 also.
Posted on: 2006/12/6 11:22
Not too shy to talk
oh mine is a 71
Posted on: 2006/12/6 12:12
From Selah, Washington
I have a clutch and brake pedal assembly that I was going to list on ebay but if you need it let me know
Posted on: 2006/12/6 13:28
