Ring gear and starter problem
From Mudgee
Have a CA and the starter seams to throw out but doesn't spring back every time. Ring gear teeth are ok and so is the pinion on the starter. Any thoughts?
Posted on: 2010/3/2 8:28
Re: Ring gear and starter problem
From Adelaide, Australia
Sounds like the solenoid is sticking, Take it apart, clean it up and it should be fine.
Posted on: 2010/3/2 8:31
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Sydney, Australia
Are you sure your starter is a CA18DE/DET one?
I don't know of any others that will fit. A 180B will bolt in.. but it has the wrong gear pitch and you'll end up breaking the nose off the starter motor.
I went through 2 starter motors in 1993 before finding this out.
Posted on: 2010/3/2 11:08
From mandurah
pull the soliniod out and lube it up and put it back together
Posted on: 2010/3/2 12:12
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
If the starter makes a whizzing sound, it is a bad overruning clutch. In this case, replace the starter drive gear assembly.
Posted on: 2010/3/2 19:45
