Car Dies when HOT with Air leak
From Sri Lanka
Hi Guys
I got my friends datto today and came , i have a problem on it, when the engine gets heated i get a air leak sound from left side of the engine bay and when it is high car is not pulling at all and dies at once, then it doesn't start until the engine get cold.what sort of a problem is that ? engine doesn't overheat or no reduction of radiator coolant
Any suggestions ?
thanks
regards
sumith
Posted on: 2011/3/16 6:57
Re: Car Dies when HOT with Air leak
I cannot guess at the air leak sound.
But the other problem sounds like a hot fuel line (fuel lock).
Posted on: 2011/3/16 7:46
From Sri Lanka
Hi DD
Yepe this is something new to me, i have never faced similer,
the sound is just like when the blower is on,increases according to the engine rpm, when it is going very high at a time then the engine dies car and pulls very weakly.
idle is ok for any time but this problem occurs while accelerating a little time and go.
thanks
regards
sumith
Posted on: 2011/3/16 8:02
From Melbourne, Australia
could it be the vacuum advance unit on the distributor? (only thing on left side with an air line) maybe there is a leak in there? test if the vacuum advance is sealed by taking the hose off at the carby... try to blow in it, if you cant the vacuum advance is sealed... if you can then there must be a hole
Posted on: 2011/3/16 9:45
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Lisboa-Portugal
Try the anti-dieseling solenoid valve, mine had the same problem.
Posted on: 2011/3/16 10:35
From Sri Lanka
thanks guys
i have a big doubt about a compressor leak too, found that radiator coolant is little oily too..
thanks
regards
sumith
Posted on: 2011/3/17 4:47
From Sri Lanka
Hi Guys
It was a blocked carburetor or similer problem, that got vanished at once while i was climbing a hill on 2nd gear suddenly , after that car was pulling normal.
thanks
regards
sumith
Posted on: 2011/3/21 7:36
