S13 front suspension in 1200
Quite a regular
Hey wondering if anyone has done a conversion using the S13 suspension and if it works. Looked up the tech wiki but have heard stories that it's not good and messes up the handling characteristics
Posted on: 2013/9/22 9:53
Re: S13 front suspension in 1200
From windsor, sydney
I have a complete s13 front setup in my ute and couldn't be happier with it , it did take a bit of tweaking to get everything to work together but now I would not contemplate any other conversion . The dampers are better and more available at the right price , the brakes are the best I have ever had ( R32 GTR skyline discs and 4 piston calipers ) or you could stick with the s13 4 stud hubs and brakes depending on what wheels you want to use , while my ute is a bit on the modified side I also have a standard coupe that I have just purchased all the std s13 stuff for and plan to get it all to fit under standard guards with 15x7.5s wheels , good luck with your project, Wards
Posted on: 2013/9/22 10:21
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Quite a regular
Some help with what to do and the setup would be really appreciated
Cheers
Posted on: 2013/9/23 1:59
From Brisbane, Australia
Posted on: 2013/9/23 2:02
