Alternative engine swaps B120 ute..
CA18, 4AGE, FJ20 or SR20?
What are the options?
Posted on: 2016/9/29 12:09
Re: Alternative engine swaps B120 ute..
Except for the FJ, those are the traditional swaps. For something alternative, try the Nissan QR20DE (instead of SR20DE) or GA16DE VCT (instead of 4A-GE) or the JZ six
Posted on: 2016/9/29 12:28
The JZ (1JZ or 2JZ) is a very short six-cylinder engine, so aside from cutting out the tunnel and re-covering it, including a portion of the firewall, it's much like any other engine swap. I see that your'e in Australia, so under NCOP is would need to be engineered under ICV rules
That's the main reason the smaller 1.8 turbo or 2.0 non-turbo engine swaps are so popular in Australia
V8 swaps into 1200s are more popular in Australia than in other countries, so for drag racing/burnout comps/off-road that's another way to go
Of the four you listed, the FJ20 is the most tough looking, but an SR20DE actually similar power in stock form (FJ20E: 148 hp, SR20DE 140-169 hp). The SR20 is lighter too
SR engine swap
FJ engine swap
Posted on: 2016/9/30 1:25
Cant put anything more the 1886cc (forced induction) 2102cc (NA) in with Tas road laws due to the weight of the ute..
Posted on: 2016/9/30 1:56
Edited by rugger on 2016/9/30 3:35:47
Well that rules out the FJ20 and SR20. Of the other two, the CA18 is slightly more powerful than the 4A-GE. Keep it real, keep it all Nissan
Posted on: 2016/9/30 4:25
Ah, I see you modified your comment. Yes, those look to be the same NCOP guidelines all the states are going by
So all the options are open
Posted on: 2016/9/30 4:28
I was talking with a guy here in the states who put a GM V6 engine into a 1200. Didn't see photos though.
Posted on: 2016/9/30 18:48
Yeah, GM 3.8 V6 into 1200 is fairly common, fit much better than the smaller ford 2.8 V6
Even better is the "Darwin Swap", they did a lot of them, street legal too with the Nissan VG20 V6
Eddie: The transplant was a great success, and has been copied by about 5 others in my home town.
Surprisingly enough there are no modifications to make in the engine bay apart from a few mountings that need to be installed to mount additional control gear.
ca18det_man:
I have helped fit a Vg20 V6 into a 1200 ute it fited quite well. It had to have a larger tunnel [1200 automatic tunnel] fitted and custon extractors to clear the steering.
Posted on: 2016/9/30 23:48
