Can you identify these castor rods?
From Newcastle, Australia
I recently pulled apart my 1200 ute's front end to change out the struts. When I removed the castor rods I noticed that they were different to to a spare set that I had stored away. I wanted to know if anyone can help identifying both pairs and suggest which ones I should use?
jpg  20161108_103741.jpg (173.60 KB)
14929_58211827ac38e.jpg 1080X607 px
jpg  20161108_103846.jpg (189.03 KB)
14929_5821183336573.jpg 550X980 px
jpg  20161108_103903.jpg (195.71 KB)
14929_5821183b443c5.jpg 550X980 px
Posted on: 2016/11/8 0:15
Re: Can you identify these castor rods?
From Las Vegas USA
It looks like the one set maybe modified so that the caster can be adjustable.
Tom
Posted on: 2016/11/10 3:15
They have been machined for extra castor
Posted on: 2016/11/10 7:02
Car free
Cheers gents. I began to think this might have been the case when I re-tapped the thread. The last inch of thread was a bit tight like it wasn't quite machined down enough.
Another question though. I noticed that on the standard set, the LH rod has a longer thread. Do you know if this is normal?
Posted on: 2016/11/11 11:14
Do yourself a big favour and throw the machined ones away-they break and then the only thing holding your wheel from flying back into the inner guard is the little sway bar pedestal.An absolute no no. Cheers Dave
Posted on: 2016/11/11 19:11
From Adelaide
I second throwing away the machined ones. Machined threads are not as strong as rolled threads and unless they've been very careful on the details there might be stress concentrations where it's been modified.
Stress concentrations are sharp edges, nicks, gouges etc that can be left by machining/ poor design. In highly stressed parts these details also tend to initiate fatigue failures which generally give you no warning before they let go. It's pretty hard to spot a crack on a thread! Pretty dodgy if the stress is high enough to cause failure (which it is if they've broken before like Dave says).
There are better ways to adjust the castor anyway. Check the wiki if you're interested.
Posted on: 2016/11/11 19:59
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Yeah ok. I have adjustable camber/castor tops on my new struts anyway. Before I go ahead and use the untouched ones though, can you explain why the threads are slightly different lengths?
Posted on: 2016/11/14 1:58
From Adelaide
Have a read of this and it'll all be clear http://datsun1200.com/modules/mediawiki/index.php?title=Castor
Basically it handles better if you shorten active length of the castor rods a bit.
Posted on: 2016/11/14 7:49
I think both sets have been modified
As far as I know, all untouched rod look like this:
Posted on: 2016/11/19 8:12
