1200 Bonnet sitting lower than front guards.
Anyone had this problem?
Where was the problem found?
Cheers :)
Posted on: 2017/3/4 7:27
Re: 1200 Bonnet sitting lower than front guards.
Yes
There are rubber spacers that go on the fender. If not missing, they can get damaged/squashed down
* Nissan Part Number 65806-H1000 BUMPER-HOOD
The thick one:
Posted on: 2017/3/4 7:39
Awesome :) thanks mate.
Posted on: 2017/3/4 7:41
Hey mate.
Looks like it latches far too low.
With the bonnet sitting on these rubbers it doesn't latch the bonnet closed.
Could there be a problem with the mechanism.... does it have an adjusting screw or something ? Or could it be that the guards are on too high....
I know the previous owners took off every panel for paint and there's a few things that arnt straight .
Posted on: 2017/3/5 3:11
Gaurds too high? Doubtful. It needs the rubbers for the bonnet to match the guards -- check the bonnet-to-guard alignment
Latch not adjusted correctly? There is no adjustment, it is spring loaded. So... check for correct mounting: Latch on core support:
Bonnet latch
Also check that the radiator core support (Front panel) is attached correctly
Is your bonnet damaged?
Posted on: 2017/3/5 3:27
From gold coast QLD.
And that the hinges are not bent or damaged
Posted on: 2017/3/5 7:58
Thanks guys will take another look in the morning.
Posted on: 2017/3/5 10:08
