« 1 (2)
Re: ****HELP!**** A12 RUNNING LIKE A DOG
I suspect fuel filter issue or bad fuel pump
Posted on: 2017/11/11 15:22
From south coast nsw
I’d Take the plugs out and that should tell u what direction to head. Probably fowled up From worn or incorrectly set point gap . A series Is very simple I’d be surprised if anything major. No Grease on the dizzy lobe will make the points close not long after changing em .
Posted on: 2017/11/13 10:51
Good idea. It's easy and costs nothing and might pinpoint a problem
Spark Plug Inspection
jpg  spark_plug_condition.jpg (83.72 KB)
174_5a0a686fe2689.jpg 800X640 px
jpg  DensoSparkPlugChart_modified.jpg (60.43 KB)
174_5a0a6882bd01c.jpg 779X600 px
Posted on: 2017/11/14 3:52
From Whangarei, New Zealand
Hi all. when I got home after it was playing up, #4 was very oily, to the point that it wasnt firing at all. Just seems to be that cylinder. Compression tests came back fine. Have changed fuel pump and filter and that made no difference
Posted on: 2017/11/24 22:23
From Sydney
Hey Dazza
Can you be a little more specific with what you did with the dizzy?
Points?
Condenser?
Cap?
Rotor Button?
Also, do you know if it is a misfire or flat spot? Have you changed the plugs since you found No.4 oiled up?
Cheeers
Posted on: 2017/11/25 11:31
Replaced whole distributor to no avail. Yep have replaced all plugs. Seems like a flatspot to me, runs extremely rich (black smoke for miles) and dies underload. No backfiring at all. Have also noticed leaks around the top carburetor gasket and throttle plunger so im guessing that is the problem
Posted on: 2017/11/26 6:37
Most common problem is the fuel level is too high. Look through the sight-glass and the level should be at the halfway mark. 2mm above half is too much. See Float for details
Another cause of these leaks is a warped carburetor top (somewhat common on the Hitachi 306). When the top warps, the vacuum leaks from the power valve passage, causing it to run super-rich all the time. You can verify this by removing the top and inspecting
* make sure gasket is not torn by center hole
* put a straight edge on the top and look for warpage
* Ensure center plunger rod is not stuck (stuck down means rich)
jpg  24081 vacuum passage for Power Valve.jpg (32.15 KB)
174_5a1a6a0540560.jpg 268X240 px
Posted on: 2017/11/26 7:15
« 1 (2)
