Correct flywheel lock or stop
Hi,
Is there an available flywheel lock or stop that is correct for Datsun a12-15 engines? Yes, I have seen the picture below as a suggested way of doing it.
Thanks
Posted on: 2020/5/1 15:09
Re: Correct flywheel lock or stop
Picture did not load previously,
Sorry
Posted on: 2020/5/1 15:11
picture attached.
Thanks
jpg  23490.jpg (73.69 KB)
11748_5eac3209af882.jpg 640X480 px
Posted on: 2020/5/1 15:28
Two bolts and a number of wraps of tie wire, if you're in a hurry.
Posted on: 2020/5/2 8:37
From Las Vegas USA
I use my extra long pry bar (square bar) and let the pressure plate locating dowels wedge either side of bar. I either hold the handle on the bar and pull against as I push down on the torque wrench or let it pin against soemthing (winging stand or ground). If I'm doing it in the car I let the bar spin against the tranny tunnel.
Posted on: 2020/5/3 21:19
