what irs diff fits a 1200 ute
Quite a regular
From gold coast
does any one know what irs will fit a 1200 as in the length a can make up all custom mounts and stuff
Posted on: 2007/2/1 8:00
Re: what irs diff fits a 1200 ute
From Perth WA
All that really needs shortening is the driveshafts. Otherwise you can just mount everything closer together.
Or you will just have to go around car parks with a tape measure measuring track width of IRS RWD cars
Posted on: 2007/2/1 8:12
Chris...
From Geelong, Vic
IRS like this
its from a 180b
Posted on: 2007/2/1 8:13
From sydney australia
nissan pulsar n14 GTiR rear suspension. Arthur Jackson is fitting (has fitted) one in a 1200 coupe he is putting a sr20de in for khanacross. he's working at Stewart Wilkins Rally at Windsor.
Posted on: 2007/2/2 17:13
Quite a regular
Don't bother, I've done a silvia IRS in a ute and I'm sure it is more trouble than it's worth. If I was to do it all again I'd just go 4 link and a watts....or something like that
Posted on: 2007/2/2 23:39
From Arlington, TX, USA
PIGDOG wrote:
IRS like this... from a 180b
FWIW, the 510/1600 has that same IRS. And is a closer fit to the width of a 1200.
Posted on: 2007/2/2 23:50
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
