A15 in a '76 B210
From Monroe, wa, usa
I just got the A15 in the B210 and it seems the crank and/or a rod is hitting the oil pan. has anyone else had this problem? I beleive a simple "adjustment" of the pan will fix it.
Posted on: 2008/1/27 3:31
NAPA parts bitch
Re: A15 in a '76 B210
From The garage, NZ
did you use the a12 sump on the a15? because the a15 sump is different to the a12. The a15 has a longer stroke and therefore needs more room. Fit an a15 sump and you'll be golden
Posted on: 2008/1/27 3:43
I had to use the A14 sump on the A15 due to the crossmember; it's a center sump. I did this once before and didn't have problems then
Posted on: 2008/1/27 4:28
NAPA parts bitch
From Los Angeles,CA. USA
Are you sure you didn't dent the pan on installation? I have the same set up on my B210...Using the B210 pan on the A14 block no problems!
Posted on: 2008/1/27 4:39
Didn't somebody say the A15 crank will hit the sides of the A14 oil pan? A15 pan has bulges in the side?
Posted on: 2008/1/27 5:09
didn't notice anything.....
Posted on: 2008/1/27 5:29
NAPA parts bitch
Mikey, what part of OK are you from? My kin is from Okeh, Checotah and Muskogee.
Posted on: 2008/1/27 5:58
I'm FROM San Diego, ca; but I LIVE in Alva, ok.
1200's had the front sump as well as 210's. My B-210 has a center sump. I cant use the front sump in it....
with my VERY worked head this thing hauls a$$!! Now I need to put in the 5 speed and/or the 210s rear end.
Posted on: 2008/1/28 0:41
NAPA parts bitch
From NZ
Keen to see a pic of this head. Sounds good.
Posted on: 2008/1/29 12:39
well; the head's gotta come off. I have between 280 and 295psi of cranking pressure per cyl.!!!!!
it haus ass though even with the timing retarded 25*. It's got so much blow-by I'm going to get a ticket.
I am going to rebuild the H72 head and put it on. I MIGHT sell this other one
Posted on: 2008/2/6 5:05
NAPA parts bitch
