carbs.
From Toowoomba, Qld
$25 well spent.
Make a manifold for the A15 at work this week, and on they go
Anyone interested in the L series manifold??
Its home made by the bloke I bought it off.
Have it for cost of postage. PM me first in best dressed
Posted on: 2008/5/27 10:57
Re: carbs.
From Wagga Wagga, NSW
Absolute Score!
I want quad Carbs for $25 No fair
Posted on: 2008/5/27 10:59
Re: carbs.
From Adelaide, Australia
pm sent
Posted on: 2008/5/27 11:04
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: carbs.
From Toowoomba, Qld
manifold spoken for.
Has anyone had experience tuning these carbs for A series before?
They have needles and seats to suit warm L16, how far will they need to be changed to suit warm A15?
And will a holley red fuel pump and reg do the job or do I need to go bigger?
Posted on: 2008/5/27 11:12
Re: carbs.
I would think the holley and reg would be suitable, Im sure they would be similar to running webers. I would search for the fuel pump flow and pressure for the bike those carbs came from and set up pump from there.
Posted on: 2008/5/27 11:21
IPRA Build
Re: carbs.
From Southern Highlands, NSW, Australia
I have a set of keihin carbs that I used on my racecar for a few years and they went pretty good. I drilled out the main jets a fair bit and packed a few washers under the heads of the needles to lift them up a bit and they ran pretty good.
Though if yours are already tuned to suit a L16 they're probably pretty close to what you need already.
I used a facet pump for fuel delivery which gave me 6 psi of fuel pressure with no dramas. I think the outlet of the stock fuel tank was too small and caused fuel starvation which led to a melted piston a couple of weeks ago.
Posted on: 2008/5/27 11:24
'72 1200 sedan hillclimb/supersprint car
Re: carbs.
From Toowoomba, Qld
what size were the fuel lines in yours DAT141? The P312 they're going into has 5/16 fuel lines, and I think the holley red is good for about 5psi, so I'll suck it and see so to speak.
Posted on: 2008/5/27 11:27
Re: carbs.
So was this setup on an L series?
Youve got me excited now!
Posted on: 2008/5/27 11:30
Re: carbs.
From Toowoomba, Qld
Yeah, it was running on an L16 in a Stanza,
The guy I bought it off picked up a L18 SSS motor after he blew the L16 up and never got around to fitting these.
Right place, right time.
Posted on: 2008/5/27 11:32
Re: carbs.
QUAD CARBS ON AN L SERIES!!!! WOOOOOPP
Thats what i want to do with my l series
Posted on: 2008/5/27 11:34
