fastest way to cahnge a camshaft on a 14
From Vanderbijlpark, South Africa
i'm getting a spare cam cut for my ute and fitting h89 head to it, the engine is standard at the moment, can i take out the engine and turn it upside down so the cam followers doesn't fall out, instead of opening up the sump? or is there a easier way?
Posted on: 2010/8/23 10:09
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
Re: fastest way to cahnge a camshaft on a 14
From Ringwood, Melbourne, AUS
You should also get the followers refaced so that the life of your cam is maximised or you risk premature failure..
Posted on: 2010/8/23 12:01
Deano
Yes you can and its the quickest and easiest way. But as ssskiwi says get the followers resurfaced to suit.
Posted on: 2010/8/23 12:05
Don't you need the sump off to properly guide the camshaft in? Taking the sump off takes a few minutes anyway.....
There isn't really a quick way. There is the proper way (reface and replace bearings) and the short cut.
Posted on: 2010/8/23 12:10
thanks guys, will rather take the long way and do it properly. thinking about doing more to the engine, once it's open and out you always stat thinking 'should i do this and that as well'...
Posted on: 2010/8/23 13:21
Replacing the bearings is not part of a "proper" job. Nissan recommends you leave the cam bearings in there unless they are worn (which doesn't often occur). If you replace them it requires line honing.
See our tech article Camshaft replacement.
Posted on: 2010/8/24 3:30
