trx bluebird rims
From sydney
i got 4 trx wheels a while back but haven't used them yet as the ute is off the road, i finally got around to getting tires only to be told i need special custom made wheel nuts, is this true?
Posted on: 2012/12/10 7:54
Re: trx bluebird rims
From Flinders View, QLD
no mate, I got TRX rims on my 1200 ute and I am using standard wheel nuts from repco, but they suit a alloy rim. What you will need to make sure is the length of the nut needs to be about 25-30mm as the depth of the hole in the rim is too deep for a standard 10-15mm wheel nut from a steel rim. Hope this makes sence, if you need I can organise a pic.
Posted on: 2012/12/10 8:11
Just trying to put the bloody puzzel back together
From Gold Coast
I got some from Nissan brand new from memory they where from a pintara.
Posted on: 2012/12/10 8:16
From sydney
yea a pic would be good, , ok i will look into it, thanks
Posted on: 2012/12/10 9:23
here ya go, the long one is what you need as is suits an alloy rim but either can be used on a steel rim. The short one is a stock standard wheel nut to suit a steel rim.
jpg  WHEEL NUTS.jpg (106.98 KB)
5996_50c5c2f19842a.jpg 800X600 px
Posted on: 2012/12/10 11:09
From sydney
and this fits the trx wheels? i have 4 that match this pic, they still didn't fit, i dont have to get longer wheel studs do i?
Posted on: 2012/12/10 11:19
Yeh mate the long ones fit TRX rims. What's not fitting on yours mate, the rim to the hub or the wheel nut too the wheel stud. Got any pics of how it's not fitting. Is there a size marked on your wheel nut if so is it 12x1.25???
Posted on: 2012/12/10 19:34
From sydney
I don't think there right anyways there only like 25 mm I couldn't get the tyre iron in the hole soo yea to short? How long would the studs have to be??
Posted on: 2012/12/10 23:54
