(1) 2 3 »
engine mounts
From Christchurch New Zealand
does anyone know if nismo have a stiffer engine mout for 1200 if so part numbers are much apreaciated
Posted on: 2002/8/17 3:42
Re: engine mounts
From sydney australia
you'd think they would,but looking through the sports option parts list i've got,in 'other parts'there is no listing for engine mounts,but lots of other good stuff,like fibre glass hatchbacks for a 120y,(if thats what frp means).when i get this scanner sorted,i should post this,as there's some good stuff in here for a12's,how about 'f5c56a 5-speed direct coupled transmission,part no 32010-h7220' or parts numbers for diff ratios to suit a h165b from 3.7:1 to 4.625:1.i've seen someone knock off the studs off standard mounts,& drill a hole & run a bolt through the mount,though you need a nylok nut.
Posted on: 2002/8/17 9:53
Re: engine mounts
From Melbourne, Australia
why do you want stiffer mounts?, what will this acheive for a rally car?
Posted on: 2002/8/17 14:29
Re: engine mounts
it's probably to stop them breaking,a problem with 1200's with big horsepower motors in them.have you thought of going to a suspension place that makes nolathane bushes with a pair & seeing if they can redo the mounts with the urethane.
Posted on: 2002/8/17 21:49
Re: engine mounts
you lose tourqe when the engine twists around
Posted on: 2002/8/18 6:42
Re: engine mounts
you would only loose a tiny bit of torque as the mount is initially loaded surely, i would think this is negligible loss and money and time could be better spent
Posted on: 2002/8/18 7:25
Re: engine mounts
as another positive the force put on the engine mounts is huge in a rally car think about it bumps jumps and any other hazard get an engine mount put it in your hand and twist it you will see how soft it is
Posted on: 2002/8/18 7:35
Re: engine mounts
yeah true, but it absorbs theese shocks and stops everything rattling to bits
Posted on: 2002/8/18 7:39
Re: engine mounts
your right but still the rubber crackes and splits in half
Posted on: 2002/8/18 7:43
Re: engine mounts
true
Posted on: 2002/8/18 7:45
(1) 2 3 »
