Browsing this Thread:   4 Anonymous Users
Thermo fan ?
From Brisbane Qld
Iam about to put in my worked A12 with A14 head I think I would like to put in a thermo fan
would one would I use ?
Posted on: 2014/6/26 3:02
Re: Thermo fan ?
Consider that the A12/A14 fan works as well as any electrical fan - and better than some thermo fans.
A12/A14/A15 uses the same fans.
Posted on: 2014/6/26 3:39
Re: Thermo fan ?
Spal brand fans come highly recommended. Some have had success with Craig Davies fans.
Here is a Spal fan
Here is a B11 fan
For more information, see Electric Fan, particularly the Aftermarket section.
Posted on: 2014/6/26 6:33
Re: Thermo fan ?
From Adelaide
I used one of these http://cgi.ebay.com.au/ws/eBayISAPI.d ... ageName=ADME:L:OC:AU:3160 on my A15. It worked well enough to stop it overheating while I was tuning it in the shed over summer. If you're planning on doing a burnout comp in summer you may want to consider something else though. I use it with a 70 deg thermal switch on the bottom pipe so it only comes on when it needs to. These one's can sink enough current http://www.jaycar.com.au/productView.asp?ID=ST3823
Hope that helps.
Posted on: 2014/6/26 8:38
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: Thermo fan ?
Quite a regular
From Vanderbijlpark.South africa
I've used a 12" davies craig fan and have a 90 deg thermo switch in the bottom hose, no problem in stop and go traffic keeps the engine cool but on the highway it just can't keep up
Posted on: 2014/6/26 8:48
1976 120Y ute (Daily)
Re: Thermo fan ?
From Kelmscott Western Australia
I used a 12 inch davies craig with the adjustiable switch with the probe slid into a metal tube solded to the toptank
And a 10 inch used on the condensor for air con
Posted on: 2014/6/26 12:54
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Re: Thermo fan ?
From Sydney NSW
If you get one it MUST have a shroud and it must draw the air through the radiator not blow it.
Posted on: 2014/6/27 23:39
Re: Thermo fan ?
Some can push, its just pulling with shroud is more efficient.
also fan shouldnt be needed on freeway over 60kmh. Airflow through rad should be more then enough to cool car down
is your core blocked?
Posted on: 2014/6/28 0:11
Re: Thermo fan ?
Do this with the switch if u want a adjustable
jpg  20140627_171558.jpg (102.43 KB)
13822_53ae93fb94c66.jpg 392X294 px
Posted on: 2014/6/28 11:08
Re: Thermo fan ?
From Sydney Australia
Just go to the Wreckers and measure up and use any Factory Fan that fits as any Factory spec fan will be bulletproof because it is made to OE standards, Plenty, Well actually all late model cars run electric fans and that will be the best and cheapect way to go unless you really want a brand new one, factory ones are reliable and often have nice mounts as well.
Posted on: 2014/7/2 22:10
