A15 Piston Rings
From Fort Worth, Texas
Ok guys I scored a set of Nissan piston rings for my A15 engine. Want to make sure I install them correctly. If there is a good link on this forum for installation please provide it. Question on the oil ring spacer. The image that shows the closeup of the rings...you can see the split on the spacer. Is that oriented correctly? Also on the top ring, instructions say to face stamp up. I have standard size rings because I only honed the block, so the "S" is facing up. The second ring shows the tapered end facing down. This all look good?
jpg  piston.rings.set.jpg (182.90 KB)
20677_5acb8fd9e2a34.jpg 750X561 px
jpg  piston.rings1.jpg (197.98 KB)
20677_5acb8fe81a8b9.jpg 800X600 px
jpg  piston.rings2.jpg (183.00 KB)
20677_5acb8ff3e358b.jpg 850X637 px
Posted on: 2018/4/9 17:11
Subject Poster Date
     A15 Piston Rings TexasMidget 2018/4/9 17:11
       Re: A15 Piston Rings vixen 2018/4/9 23:14
         Re: A15 Piston Rings ddgonzal 2018/4/10 1:08
       Re: A15 Piston Rings TexasMidget 2018/4/10 3:12
         Re: A15 Piston Rings ddgonzal 2018/4/10 4:53
       Re: A15 Piston Rings Rallytwit 2018/4/10 5:22
       Re: A15 Piston Rings TexasMidget 2018/4/11 3:33
       Re: A15 Piston Rings TexasMidget 2018/4/11 14:42
         Re: A15 Piston Rings ddgonzal 2018/4/12 0:57
           Re: A15 Piston Rings ddgonzal 2018/4/12 0:59
             Re: A15 Piston Rings TexasMidget 2018/4/12 3:34
               Re: A15 Piston Rings ddgonzal 2018/4/12 10:52
