A15 Piston Rings
From Fort Worth, Texas
Ok guys I scored a set of Nissan piston rings for my A15 engine. Want to make sure I install them correctly. If there is a good link on this forum for installation please provide it. Question on the oil ring spacer. The image that shows the closeup of the rings...you can see the split on the spacer. Is that oriented correctly? Also on the top ring, instructions say to face stamp up. I have standard size rings because I only honed the block, so the "S" is facing up. The second ring shows the tapered end facing down. This all look good?
jpg  piston.rings.set.jpg (182.90 KB)
20677_5acb8fd9e2a34.jpg 750X561 px
jpg  piston.rings1.jpg (197.98 KB)
20677_5acb8fe81a8b9.jpg 800X600 px
jpg  piston.rings2.jpg (183.00 KB)
20677_5acb8ff3e358b.jpg 850X637 px
Posted on: 2018/4/9 17:11
Re: A15 Piston Rings
From gold coast QLD australia
You are spot on just check ring gap and your good to go.
Posted on: 2018/4/9 23:14
Edited by vixen on 2018/4/10 6:45:15
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
Nice, those are genuine Riken Rik-Vent rings
Here's the B310 A14/A15 factory service manual:
translation:
Point the inscription upward
- Top Ring
- Second Ring
Oil Ring
jpg  132a Piston Ring Assembling.jpg (44.12 KB)
174_5acc00691d18f.jpg 800X496 px
Posted on: 2018/4/10 1:08
Thanks Vixen/DD. For some reason my machine shop guy told me install the oil ring spacer with the ends pointing up. Any idea why? The instructions say to install the ends pointing down.
Posted on: 2018/4/10 3:12
It may not matter, both ways may work well. Still, I'd go with the manufacture recommendation
What does it say above the ring diagram?
jpg  Mating point shall beonthe Lower Side.jpg (34.14 KB)
174_5acc3536c3060.jpg 400X300 px
Posted on: 2018/4/10 4:53
From Las Vegas USA
I've always followed what is on the directions and never had an issue.
Posted on: 2018/4/10 5:22
Text above diagram says "Colored Section". I will go with the instructions and face the channels down.
jpg  ring.text.jpg (69.71 KB)
20677_5acd73a58d659.jpg 1932X2576 px
Posted on: 2018/4/11 3:33
DD/RT,
Here is what my machine shop guy says about positioning the oil ring expander facing up. If you can follow his logic let me know what you guys think...
"on some pistons the oil return holes that are drilled thru the ring land on the oil control ring are below the bottom land. If by chance the expander catches on the edge of the hole it will distort and put uneven pressure on the oil control rings which will make the engine use oil or not seal the cylinder well. My way is just a precaution that i have learned over the years"
Posted on: 2018/4/11 14:42
Interesting. Here are some A14 pistons by Matsuoka that have two kinds of ring land holes -- some drilled inwards and some drilled diagonally
jpg  DSC_0251.jpg (30.16 KB)
174_5acea0031f099.jpg 640X425 px
jpg  DSC_0249-1.jpg (23.30 KB)
174_5acea00f1f0aa.jpg 640X425 px
Posted on: 2018/4/12 0:57
Here is a Cosworth A14 piston with holes drilled inward
Posted on: 2018/4/12 0:59
