These are almost ready to sell, as mentioned in the other thread I'm just waiting on the delivery of the horn rings for the back of them
I thought I would put up some pics to get some interest rolling. After an initial batch here I will sell these long term on eBay
The entire kit in pieces
The kit mounted on a wheel (as intended for use in a ute)
height comparison vs. the current/cheap ones
So the benefit's are obvious for the ute's, you will be able to drive with straighter arms and it will be much easier to get in and out of the vehicle
But also this would suit people wanting to fit quick release steering wheel kits as you can mount the release between my short boss and the steering wheel. Your steering wheel should then be roughly back in the original position (release kits are approx 25mm long)
Or if you would like to fit a deep dish wheel to a coupe or sedan this kit would be of benefit also as you can mount it further away also.
If you use this kit with a flat wheel mounted in the "low" position, you will need to bend your indicator stalk back to accommodate the new position. This is not difficult to do, just grab and bend.
Price will be $99 delivered, it includes all items shown in the first pic (boss, spacer, horn button, button mounting ring and bolts) The boss has fully functional horn and roll pins for cancelling indicators
