Well its been a long time coming but here's my official build thread. I started on this thing back in 07, bought it in 05 & it sat waiting for a while till I tackled it so I started with this...
did lots of patches & welding...
Finally got it stripped down to the metal & did some dent pulling...
the roof had lots of dings & I metal shrunk it to get rid of the oil canning effect then filled & sprayed poly filler - Featherfill G2
Got it into epoxy both on the bottom & top, bottoms black & staying that way, tops white epoxy..
then I built a motor, a 5 spd., readend assemble, struts, & tons of other crap...
thats my stock 1200 radiator recored w/a 3 tube core & a camry electric fan mounted w/a sensor..
my rebuilt struts..
did a little plastic repair & painted w/SEM hot rod black in satin...
finally got the base coat on..
then the clear today 3 coats, will need sanding then another 2 coats, cut & buff then maybeI can find time to assemble it all back together...
this was a massive amount of work but worth it & I've enjoyed the process but I'd like it on the road so I better get my ass in gear! Hopefully this'll inspire some of you to keep going, I know it was threads like these that kept my interest at times.
Thanks everyone whose helped me out over the years, I appreciate it!
evan
