A14/12 Pulleys
From Brisbane
water pump pulleys on the a12 are they the same as the a14? are they interchangable? are there any odd water pupm altercations?
Posted on: 2003/5/20 14:37
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: A14/12 Pulleys
There are at least two pulley setups for the A-series. There are also varying lengths of the fan spacer.
The water pumps are interchangeable.
Posted on: 2003/5/20 16:50
Re: A14/12 Pulleys
From Brisbane
well my problem is i get my A14 soon and wanted to know if my A12 pulley will convert on to it and whether it will function properly?
so i thought my best bet was to get a A14 pulley then i know it would go straight on, unless someone has used there A12 on a A14???????
Posted on: 2003/5/24 13:45
Re: A14/12 Pulleys
From Canberra, Australia
Do you just mean the water pump? Cos I am pretty sure they are the same thing. I am 95% sure that they were the same part number.
From when I changed it on my A12 and then again after when I changed it on my A15...
Posted on: 2003/5/24 14:12
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: A14/12 Pulleys
From Brisbane
yes the water pump pulley
Posted on: 2003/5/25 2:06
