« 1 2 (3) 4 »
Re: what gearbox is it?
From Melbourne, Australia
i fvcked up
im pretty sure it's a 4-speed with a rat shiet selector the makes it seem like your picking a gear in place of fifth
it looks just like that a-12 box pictured above
Posted on: 2003/6/19 12:47
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From UK
How easy is it to get hold of A series 5 speeds in Aus? There are extinct here.. I have only ever managed to find one. Just wondering as a friend is going to be shipping a 720 ute back from Sydney soon and I could chuck one in the back of it.
Posted on: 2003/6/19 16:54
From Millgrove Vic OZ
A series 5 speeds are very hard to get here and bring big bucks. To recondition one typically costs $350 - $400 and they bring $750 when done up.
The 63A boxes are like gold. I have only had two in the last 4-5 years. I have heard of suzuki 4wd owners paying $1400 for them.
Posted on: 2003/6/19 23:50
Cheers Feral
There is also a dogleg shift pattern 60 series box as well as the 63A box. The box number is 60A #9 or something like that.
Posted on: 2003/6/19 23:58
Cheers Feral
From UK
The only one I have ever found was a brand new one and I paid roughly $450 for it so I guess that was a bargain.
The only place the A series 5 speeds seem reasonably easy to find is the US it would appear. Hey, maybe I can make a cable shifter to work a vanette 'box! Hmmm...
Posted on: 2003/6/20 0:00
1200rallycar, are you certain you don't have the rare as F5W56 direct 1:1 5-speed? They look just like the F4W56 4-speed (not that I've actually ever seen the 5-er). [edit: the B110 5-speed is numbered F5C56A]
Posted on: 2003/6/20 5:37
From sydney australia
yes micheal,quick way to tell if it's a 5w56 is,where is the drain plug for the box.if it's in the sandwich plate between the front & rear housings,thats definitely a 1 to 1 five speed.& yes i found 4 speeds that'll pop into the 5th gear position.the next question is,where's reverse.if it's to the left & forward,it's a 5w56.if it's to the right & back,take it back & get your money back.also,when its in the 'fifth' possie,can you turn the input shaft,but hold the output,use a gearbox plug if possible to hold it.good luck,hope it's not a dud.
Posted on: 2003/6/20 13:34
um, anywhee you put the shifter (including neutral) the output turns when turning input, but it does turn the opposite way when right and down so looks like its a dud
ill post pick showing drain hole
Posted on: 2003/6/20 13:47
1200 Coupe Rallycar
From Charlotte NC USA
could it be a sunny310 box they are verry common here in the states BTW the b210 5 speed was avalible in the states but that box is a rare item even here
Posted on: 2003/6/20 21:48
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
ive taken it back and the wrecker gave me a credit note for the price of it
Posted on: 2003/6/21 4:21
1200 Coupe Rallycar
« 1 2 (3) 4 »
