a14 timing?
From Wagga Wagga, NSW
i wasnt sure, so i set it at bout 7. is that right?
Posted on: 2008/11/30 10:00
Re: a14 timing?
From South Coast NSW - Australia
Depends on the CAM.
I usually set all my rally engines at 32degrees at about 6000rpm. Tends to work out to about 19degrees at idle.
DO NOT DO THIS - if it is a standard A14 or there will be bits of piston all over the place
Others will be about to help out soon I am sure. I would think that 7 degrees would be a little conservative, but I think it is what the manual says.
I am only answering because no one else has, others with far more knowledge can chime in any time.
Posted on: 2008/11/30 22:05
Datto 1200 Coupe - Rally Car A14
Datto 1200 Coupe - Rally Car - in pieces
Datto 1200 sedan - Khanacross Car
180sx - Rallycar under construction.. yeeha
Re: a14 timing?
Stock A-series is 5-10 degrees BTDC. For all of them: A12, A14, A15.
Posted on: 2008/12/1 2:52
Re: a14 timing?
thanks
Posted on: 2008/12/1 2:53
Re: a14 timing?
Not too shy to talk
From MT
1980 Nissan factory service manual (usa) for engines A12, A14, A15 says 8 deg +/- 2 deg, and for Canada 10 deg +/- 2 deg. Hope this helps
Posted on: 2008/12/1 3:01
