Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Chris's Rip Snorter A12 & Red B10
aidaniel
Posted on: 2009/9/10 13:00
nice to finally see this up here chris
havent change the camera back to colour since the party aye?
#12
m_amery
Posted on: 2009/9/10 22:49
I think the black and white photos make it look sicck. awesome stuff. = ]]
#13
clyons8
Posted on: 2009/9/10 23:58
Cheers Aiden, read the last paragraph of the first write-up:
"The black & white photo's are just as the camera is. It appears since the recent "Souf Ostraya" Datsun party my camera seems to have a hang-over (stuck on black & white)." I need to talk to you about machining stuff again.
#14
clyons8
Posted on: 2009/9/17 9:45
Electronic ignition, 12mm spark plug leads
![]() Previous owner obviously didn't have his timing sorted, I am hoping that this is the extent of the damage, will check associated parts in case of damage - 1.5mm over-sized pistons with valve recesses ![]() Give an idea of valve size ![]() Here is a larger shot of the work extent on the crank ![]()
#15
supafatto
Posted on: 2009/9/17 10:05
looks nice chris
did u have any luck wit thaT elec dizzy i sent u
#16
clyons8
Posted on: 2009/9/17 15:33
Hey Nick,
Nah mate, I ended up throwing it out. The vacuum was shot as well as the spindle at the center of it. There were ball bearings rolling around in it so it was pretty shot. It would have cost the same price again (probably more) just to get all the replacement parts. I ended up buying a dizzy from Mal for the B10 now.
#17
aidaniel
Posted on: 2009/9/18 5:39
yea man anytime ... im just a phone call away
#18
clyons8
Posted on: 2009/10/2 11:55
#19
Gylezy
Posted on: 2009/10/5 11:35
gday chris. were you still keen to make up a engine running stand? or did you wanna put all that running gear into that 1000 ? now its all back together it shuld be all good, did you reset the timing on it?
haha cheers Dan
#20
clyons8
Posted on: 2009/10/6 7:51
Hey Dan,
I am definitely keen to get an engine stand made up. I need to get a drawing together and all that though and I'm running out of time, seems there aren't enough hours in the day. I also have another little job that will get you some quick cash, I'll ring you tomorrow with some details, it is straight forward welding that should take only a couple of hours. Timing issue was solved and it wasn't as serious as I initially thought. Cheers You can view topic.
