« 1 (2) 3 4 5 ... 20 »
Re: Chris's Rip Snorter A12 & Red B10
From northern 'burbs adelaide
nice to finally see this up here chris
havent change the camera back to colour since the party aye?
Posted on: 2009/9/10 13:00
From South East Brisbane
I think the black and white photos make it look sicck. awesome stuff. = ]]
Posted on: 2009/9/10 22:49
Cheers Aiden, read the last paragraph of the first write-up:
"The black & white photo's are just as the camera is. It appears since the recent "Souf Ostraya" Datsun party my camera seems to have a hang-over (stuck on black & white)."
I need to talk to you about machining stuff again.
Posted on: 2009/9/10 23:58
Electronic ignition, 12mm spark plug leads
Previous owner obviously didn't have his timing sorted, I am hoping that this is the extent of the damage, will check associated parts in case of damage - 1.5mm over-sized pistons with valve recesses
Give an idea of valve size
Here is a larger shot of the work extent on the crank
Posted on: 2009/9/17 9:45
looks nice chris
did u have any luck wit thaT elec dizzy i sent u
Posted on: 2009/9/17 10:05
Car free
Hey Nick,
Nah mate, I ended up throwing it out. The vacuum was shot as well as the spindle at the center of it. There were ball bearings rolling around in it so it was pretty shot. It would have cost the same price again (probably more) just to get all the replacement parts.
I ended up buying a dizzy from Mal for the B10 now.
Posted on: 2009/9/17 15:33
yea man anytime ... im just a phone call away
Posted on: 2009/9/18 5:39
Slight freshen up on the engine and it's back together. Suspect rocker bolt though, doesn't want to torque up. Looks like it'll need a helicoil or timesert.
60 series conventional shift 5 speed from Mal
Coming together...sloowwwly
Posted on: 2009/10/2 11:55
From SA
gday chris. were you still keen to make up a engine running stand? or did you wanna put all that running gear into that 1000 ? now its all back together it shuld be all good, did you reset the timing on it?
haha
cheers
Dan
Posted on: 2009/10/5 11:35
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
Hey Dan,
I am definitely keen to get an engine stand made up. I need to get a drawing together and all that though and I'm running out of time, seems there aren't enough hours in the day.
I also have another little job that will get you some quick cash, I'll ring you tomorrow with some details, it is straight forward welding that should take only a couple of hours.
Timing issue was solved and it wasn't as serious as I initially thought.
Cheers
Posted on: 2009/10/6 7:51
