« 1 (2)
Re: 1600cc A15
Chris
Your arithmetic is good, you didn't read the original post carefully enough.
78.5mm bore X 82mm stroke gives 1588 cc.--- just the deal for up to 1600cc!
StewMck
Posted on: 2003/11/16 22:19
Re: 1600cc A15
Thanks to all who replied, I'll check all these out and advise the result later.
Stew. McK.
Posted on: 2003/11/18 22:11
Re: 1600cc A15
From Melbourne, Australia
isnt there a % leeway or something on that anyway that allows you to go slightly over the 1600cc legally?
Posted on: 2003/11/18 22:59
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: 1600cc A15
The short answer is "I dunno".
If I can make an engine under 1600cc fairly easily, thats the way I'd prefer to go.
It could make for fewer problems if ever the head is taken off for the purpose of measuring the bore and stroke.
Posted on: 2003/11/19 22:10
Re: 1600cc A15
From sydney australia
looking it up in the cams manual for improved production,it states that 'a vehicle will remain eligible for the nominated class provided the actual capacity does not exceed the class capacity limit by more than 2%'.this means 1600cc + (16 x 2) cc,or 1632 cc.so 1608 looks legal.better order those 79mm pistons to suit a a15 pin height now.
Posted on: 2003/11/21 9:50
Re: 1600cc A15
89mm
I was replying to the post immediately before the one you refer to. Demojob had refered to some 79mm pistons that he had used in his engine, hence the mathematics.
When i asked "did i get that right?', i meant, would "would 1608cc put you over the limit & disqualify you from the class you wish to race in?'
According to B310GX, it would not. Woohoo!
Chris
Posted on: 2003/11/21 13:39
Re: 1600cc A15
From T'ville
when I built my engine SSS in sydney supplied a set of mazda E5 pistons these are 80thou over and set up to go in, had the tops milled to stay just under 10:1 for pump fuel. the small end of the rods had to go to 20mm, turned out good , been for 3 yrs now
Posted on: 2003/11/22 7:57
Re: 1600cc A15
Dodgeman---Sorry, the way these threads are set up looked like your arithmetic was on the ordinary side. Again apologies.
Looks like Mazda pistons are the go!
I'll post progress reports.
Posted on: 2003/11/25 3:43
Re: 1600cc A15
89mm
If thats the biggest blooper we make in our lives, then we doin' jess fine. No appology necessary
Chris
Posted on: 2003/11/25 10:18
« 1 (2)
