« 1 ... 21 22 23 (24) 25 26 27 ... 67 »
Re: pigdogs CA 1200 wagon
From Armidale N.S.W
Lookin good matey. Just in case ya didn't think of it. If ya using the kill rust enamel from the tin might help to get a small tin of enamel hardener and add a little it should help with the drying and will reduce the paint scratching/chipping easy as most enamels do even on the inside. Due to the fact that enamel doesnt by nature dry hard without hardener. P.S Thanks for the bits got em yesterday let me know when the other bits are up for sale.
Posted on: 2010/6/28 22:41
73 1200 wagon SOLD
if it doesnt work does that mean another franken piggy brake set up for the rears?
Nick couldnt use the carrier on a later h190?
Also if you can get a heated room youll be better off especially if it can
sit at around 50 degrees overnight and day it should set much tougher.
I used the cheapest 2 dollar enamel red on my steelies and let them sit
in a tin shed during the summer and they are almost scratch proof.
Posted on: 2010/6/28 23:34
From Geelong, Vic
yeah did i bit of testing of the kill rust...matt black kill rust dries fine over the seam sealer, seems that its only the green that really has a problem with it
D, yes i could use a later H190 housing, but then i'd need to find different axles that are long enough to be shortened or short enough to not need it. bluebird ones are not long enough to be shortened to the right length
cant say i'll be getting a bake room for the enamel to set worst case is i just paint it again at a later stage. but then its not paint you will see so i dont really care that much
rightio, actual update. spent a good 10 hours on the car yesterday bogging the rear quarters and stuff. was in too much of a rush to remember to take a pic of the bog before it got painted. so these will have to do, paint is rather thin on the inside but i figure that it doesnt need that much etch on the inside as there was paint there to start with
also found out why enamel and acrylic dont like each over when i etched over some killrust that was on the end of the sill...nice paint stripper effect
quarters didnt come up to bad, still gotta smooth the bottom of the drivers side and fix up a couple of other small spots ive noticed but it wasnt really too bad for the care factor i had at the end of the day
going out to drill some holes in the roof so that its ready to be welded on as ive given up on trying to find a spot welder
and hopefully might have the engine bay primed over the weekend and the bog finished off
Posted on: 2010/7/2 1:03
From Geelong, Vic
109 holes later the roof is kinda ready to be welded, just gotta clea everything up now and find a whole heap of g clamps
Posted on: 2010/7/2 2:10
Looks tough as man GREAT WORK! keep it going cant wait to see the finished project!!
Posted on: 2010/7/2 3:01
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
yay- almost paint ready. maybe just paint it all in kill rust black
Posted on: 2010/7/2 3:45
From Geelong, Vic
right, was going to aim to finish off the bog, prime the engine bay and get the roof ready to weld on...but it seems that i had a big night last night that came from no where
so now its 1:30 and ive not made it out to the shed yet...think i'll aim to get the roof done so it can be attatched during the week then if i finish that off quick enough maybe do the bog
Posted on: 2010/7/4 4:22
so did you get the bog done? would be better than my job. fake dremel broke so had to do by hand- lost patience and the finish isnt crash hot- but was planned to be a temp job.
Posted on: 2010/7/4 9:16
From Geelong, Vic
got the roof ready to go on, then a mate called up and wanted a hand to do manual swap on his new ke20
Posted on: 2010/7/5 1:20
