I'm currently in the process of doing exactly the same setup with HSD kit. Have stripped the struts so they can be shortened and sleeves welded on.
Great info for the nitty gritty details and benefits that can be made by small adjustments, such as the kings instead of tender springs.
I'm getting some bump steer spacers made up aswell very similar to benny's to fix the LCA problem.
I'm going for the Golf inserts, just wondering if i should use them on their own or space them up an inch as benny has said previously.
Or possibly use N10 Pulsar inserts which are the same leg length, but have 15mm longer body,
Would this be a better option?
I'm hoping to be able to lower it 3 inchs at least
Just don't want to cut them wrong and waste the struts, I wanna make sure i'm doing it properly and its going to work and handle.
Some good info here:
Shock numbers
