« 1 (2) 3 4 5 ... 10 »
Re: s/charged a14
From South East QLD
I Have a A series " Crow " Cam which i got custom ground for a A series supercharger set up .. I never use it due to not finnishing the engine .. Let me Know if some one is after it ..
BTW ,, The easy way to drop the compression is to Use A15 engine with a A14 crankshaft .. Cheers Cam
Posted on: 2004/1/7 8:53
Re: s/charged a14
From campbelltown (sydney) australia
this morning i woke to find a magazine my bro bought home for me which shows and gives info about a gold datsun 1200 ute with an a15 supercharged, it even says what suspension and brake upgrades he used and they are in no way extreme, i think this is the way im going to go when i build my engine.
Posted on: 2004/1/7 10:41
Re: s/charged a14
From Brisbane
WHAT MAG!!
Posted on: 2004/1/7 10:43
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: s/charged a14
street style mag ill scan em for u and send em on msn
Posted on: 2004/1/7 11:47
Re: s/charged a14
i was just going through old threads and saw this about a14 crank in a15, is this possible and does it do as cam stated?
ill need someway of lowering comp for s/c.
Posted on: 2004/1/14 4:22
Re: s/charged a14
From Christchurch NZ
Hey Kegs, what blower are you gonna use?
The easiest way to lower your comp is with a steel shim. On my a14 with a1.5 mm shim,
my cylinder head guy calculated the comp at 7.9:1. I think the shim was made by ACL,
but Ill have to double check( it was an off the shelf item anyway).
Bart
PS My blown a14 should hopefully be cranking soon.
Posted on: 2004/1/14 5:41
Forced Induction!
Re: s/charged a14
With a single Hitachi carb, aren't you going to limit your horsepower to about 80 hp? I always thought that was the reason the A12, A14 and A15 all made around the same peak HP. Surely a bigger carb will give a supercharged engine more top end.
On the other hand, your low speed power should improve a lot. For example: 80hp at 3000 rpm, 4000rpm, and 5000rpm
Posted on: 2004/1/14 6:43
Re: s/charged a14
Nah Im gonna use a webber downdraft of
a 2L ford and if nthing too catastrophic
goes wrong I think Ill swich to a 350cfm Holley
Posted on: 2004/1/14 7:45
Forced Induction!
Re: s/charged a14
i plan to use a supra supercharger off a 1g-gze engine. should go pretty hard with a couple 'o' su's on the inlet.
who said anything about hitachi carbs?
Posted on: 2004/1/14 8:46
Re: s/charged a14
kegs asked:Quote:
It's up above:Quote:
I am using a blower of a toyota 2L V6 ... Presently the motor is only runny a standard hatachi carb with bigger jets.
But he was just running the Hitachi to break in the cam, etc before going to the next level. Sounds like a reasonable plan.
Posted on: 2004/1/14 9:16
