Who runs a turbo A-Series? Want to trial a decompression shim (free)?
Anyone keen to wind up their boost?! (safely)
I have a 2mm shim here and a 3mm shim for someone to test out (78mm bore).
Would prefer someone who knows what they're doing as I don't really want to deal with an engine failure due to lack of technical savvy. Also looking for some decent technical feedback, I.E; relevant comp ratio, fuel (octane rating), engine specs and boost pressure, and some notes on it's general performance. I can provide accurate figures for the additional introduced volumes.
One shim is un-used and the 2mm shim has been used with a safe 8:1 comp ratio on a NA engine, removed properly so it's nice and flat. Both items are mild steel.
PM me for details, I guess if it works out well and you like it you can hang onto it (on the grounds that you provide me with some quality feedback).
I can assist with some pointers on installation and gasket adhesive to save you the hassle (adhesive is Hylomar - I have a tube here somewhere) etc as I personally installed one of these on my NA engine.
Cheers.
Chris
Posted on: 2010/11/8 2:00
Edited by clyons8 on 2010/11/8 8:44:33
Re: Who runs a turbo A-Series? Want to trial one of my decompression shims (for free)?
From Christchurch NZ
You can buy Copper head gasket cement in an aerosol can. Thats how I glued the shim on my engine.
Posted on: 2010/11/8 3:36
Forced Induction!
Hey Thanks Bart,
Yeah the Hylomar was a little too difficult to apply evenly as it hardens once exposed. So an Aerosol would be tops. Could you recommend a brand name of the copper gasket spray? otherwise I'll just try the one the shop recommends.
Chris
Posted on: 2010/11/8 8:38
Re: Who runs a turbo A-Series? Want to trial a decompression shim (free)?
From Freo
you can get Hylomar in a spraycan too Chris...
I'd be up for one, but it's the high comp motor on the list first.. :) boost next..
Posted on: 2010/11/8 9:01
A15 PSI Project Motor
'72 CB750k,
From mandurah
i might be going turbo soon and ide pay for the shim ,but ive had 60thou taken off my head and its on an a12 so im not sure if it would be doable with my head
ill pay you for th shim too chris :)
Posted on: 2010/11/8 9:04
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Freo
Posted on: 2010/11/8 9:06
'72 CB750k,
I just use the VHT stuff. The can cost something like $18-$19 from memory, but I got plenty of use out of it.
Posted on: 2010/11/9 3:36
Forced Induction!
