« 1 2 (3) 4 5 6 »
Re: Webers, Alloy Diff Centre, Datsun 1000 Parts Miscellaneous Datsun Parts for Sale Adelaide
Not too sure yet D.
Last bump for webers, going on eBay now.
Chokes: 30mm
Primary Jets/Pump Nozzles: #45
Main Jets: N/A
Main Air Jet: N/A
Throttle Valves: 79°30
Rebuild Kit: Comprehensive.
Parts Replaced:
- All Material Gaskets
- All Rubber Seals
- All aluminium Washers
- All Copper Washers
- Float Pin
- Float Valve
- Throttle Shaft Spring
Posted on: 2010/12/5 8:29
BUMP>
Weber adapter plate is back up for sale.
Posted on: 2010/12/6 12:25
From Las Vegas USA
After I source a gearbox for my coupe, I'd be interested in the Alloy center diff. Any idea how much to ship to Lost Wages (Vegas) USA?
Tom
Posted on: 2010/12/7 2:50
Hi Tom. The alloy centre weighs approximately 7kg. Price negotiable seeing as freight is quite the killer.
Express Air: AUD$165.75
Air Mail: AUD$134.55
Sea Mail: AUD$82.80
Chris
ENKEI - Compe 8's ( AKA 'Comp-eights')
Anyone interested in this set? Just recently painted and polished, centre caps included, 13 x 6 rare Enkei Compe-8's VERY light rim- perfect for Datsun 1000. No chips, no marks, no bends. These ARE NOT MINILITES/SUPERLITES but they are lighter.
Posted on: 2010/12/7 3:15
Re: Webers, Alloy Diff Centre, Datsun 1000 Parts ENKEI Compe-8 Wheels Adelaide
From Las Vegas USA
Those are reeeally pretty...............hmmm so what do you think to shipa da lote to Amair-e-ga? What do they weigh?
Tom
Posted on: 2010/12/7 3:40
To ship the lot? These are 4.0kg per wheel. Superlites are something like 5.56kg each (13 x 6).
At the moment it's overweight for the 20kg limit, so it'd be two parcels. 17kg parcel: Air mail $276.10 Sea Mail: $162.10 (approximate prices).So add those with the freight quote I gave you before for the diff centre and that is about what it comes to I guess.
Posted on: 2010/12/7 3:58
From Ringwood, Melbourne, AUS
Nice looking wheels! I am biased tho as I also have a set I got from JP , don't look anywhere near as good as those tho!
As Chris said, very light wheels, fantastic for keeping unsprung weight to a minimum.
What offset are they? EDIT: Ah ha, OK, I can see they are 15 when looking at the full size pic.
Posted on: 2010/12/7 8:07
Deano
Thanks Dean, I didn't even pay attention to that number. Was just about to lay the rims out and begin measuring the offsets.
That sort of figure makes sense but there is also a fair bit of dish for a 6 inch wide rim and there is another number on the back that ends in -1, so if you could clarify that that number on it's own stamped on the inner rim is indeed the offset figure then I'll start checking them anyway to see if they are +15.
Posted on: 2010/12/7 10:05
When I bought mine off Yahoo JP they were listed as +15 offset (and have the same 15 on the inner rim) and they are 13x6 exactly the same as yours, just gold and not as shiny
The lip on mine is 30mm..
I checked out some 14x7 +10 a few months ago, they were also marked with a 10 on the inner rim.
Posted on: 2010/12/7 10:30
Deano
bump
Posted on: 2010/12/8 6:13
« 1 2 (3) 4 5 6 »
