« 1 (2)
Re: Pesky stud
From Sydney, NSW
how do those guys work? looks like you can hammer them in or drill? confused? or do the drill bits just correspond to the right size extractors?
What are each of the little pieces labelled b10 etc?
Posted on: 2011/7/27 1:26
Re: Pesky stud
From Sydney
drill hole using drill bit and the "B" part to drill square into the broken stud , hit "drift' into hole that is matched to the drill bit. Slide the little hex piece "D" part over the "drift" so that you can use a tool to turn the broken stud.
Posted on: 2011/7/27 1:38
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
« 1 (2)
