#1 checking valve timing?
a12datto120y Posted on: 2011/12/15 7:59
ok so tomorrow i am going to remove the timing cover to check my cam timing due to my off idle hesitation and sluggishness that is carried on from 4 different carburettors so i can conclude the carburettors are fine.
so when i open up the cover what should i look for i know theres a mark on the cam and crank sprockets but how should they be lining up at TDC 1 and how can i tell if the cam timing is right or incorrect?
Thanks!
#2 Re: checking valve timing?
ddgonzal Posted on: 2011/12/15 8:44
Super easy. Getting the cover off is not, but once off, checking the cam timing is super easy.
just look for the key groove to line up with the dowl hole:
CAUTION: Don't try to line up the match marks. That only works when installing a chain, not after it's been put on and the crank rotated.
#3 Re: checking valve timing?
a12datto120y Posted on: 2011/12/15 8:53
ok so should it match up at TDC piston one?
Thanks!
#4 Re: checking valve timing?
ddgonzal Posted on: 2011/12/15 8:55
It should match up when you rotate the crank until the key is in the position shown in the diagram.
Like this:
jpg  Camshaft_Timing.jpg (38.78 KB)
174_4ee9b6405e4fc.jpg 640X560 px
#5 Re: checking valve timing?
a12datto120y Posted on: 2011/12/15 9:00
ah okay makes sense thanks again.
#6 Re: checking valve timing?
1200rallycar Posted on: 2011/12/15 11:05
still haven't bought the service manual?
#7 Re: checking valve timing?
a12datto120y Posted on: 2011/12/16 3:06
Okay so i got the cover of and did as instructed and it look realy close but how can you double cheak with a straight edge if the crank is in the way
Thanks
#8 Re: checking valve timing?
ddgonzal Posted on: 2011/12/16 3:27
Look at it from above, sighting down along the gear faces.
Turn the engine back a ways, and then slowly forward (clockwise) until the cam dowl lines up with the centerline of the crank. That way the tension of the chain is drawn.
After that is done, look where the crank key is. Does it look like the black line or one of the red lines? It can only be off by a whole tooth, so it will be fairly obvious:
jpg  Timing_Chain_alignment_2.jpg (40.86 KB)
174_4eeaba8fc7535.jpg 640X560 px
#9 Re: checking valve timing?
a12datto120y Posted on: 2011/12/16 5:09
ok i have checked and every thing seems okay which is good but bad in another way that i was hoping it would be the fix to my situation.
#10 Re: checking valve timing?
bige Posted on: 2011/12/16 5:25
easily way; 10 links from dot to dot, water pump side. dot to be in middle of first link(cam gear dot) then count 10 to the next middle(crank gear dot)link.
