checking valve timing?
From vic
ok so tomorrow i am going to remove the timing cover to check my cam timing due to my off idle hesitation and sluggishness that is carried on from 4 different carburettors so i can conclude the carburettors are fine.
so when i open up the cover what should i look for i know theres a mark on the cam and crank sprockets but how should they be lining up at TDC 1 and how can i tell if the cam timing is right or incorrect?
Thanks!
Posted on: 2011/12/15 7:59
Re: checking valve timing?
Super easy. Getting the cover off is not, but once off, checking the cam timing is super easy.
just look for the key groove to line up with the dowl hole:
CAUTION: Don't try to line up the match marks. That only works when installing a chain, not after it's been put on and the crank rotated.
Posted on: 2011/12/15 8:44
From vic
ok so should it match up at TDC piston one?
Thanks!
Posted on: 2011/12/15 8:53
It should match up when you rotate the crank until the key is in the position shown in the diagram.
Like this:
jpg  Camshaft_Timing.jpg (38.78 KB)
174_4ee9b6405e4fc.jpg 640X560 px
Posted on: 2011/12/15 8:55
From vic
ah okay makes sense thanks again.
Posted on: 2011/12/15 9:00
From Melbourne, Australia
still haven't bought the service manual?
Posted on: 2011/12/15 11:05
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From vic
Okay so i got the cover of and did as instructed and it look realy close but how can you double cheak with a straight edge if the crank is in the way
Thanks
Posted on: 2011/12/16 3:06
Look at it from above, sighting down along the gear faces.
Turn the engine back a ways, and then slowly forward (clockwise) until the cam dowl lines up with the centerline of the crank. That way the tension of the chain is drawn.
After that is done, look where the crank key is. Does it look like the black line or one of the red lines? It can only be off by a whole tooth, so it will be fairly obvious:
jpg  Timing_Chain_alignment_2.jpg (40.86 KB)
174_4eeaba8fc7535.jpg 640X560 px
Posted on: 2011/12/16 3:27
From vic
ok i have checked and every thing seems okay which is good but bad in another way that i was hoping it would be the fix to my situation.
Posted on: 2011/12/16 5:09
From sydney.nsw
easily way; 10 links from dot to dot, water pump side. dot to be in middle of first link(cam gear dot) then count 10 to the next middle(crank gear dot)link.
Posted on: 2011/12/16 5:25
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
