Source for stock A15 pistons with 10cc or less dish??
From Las Vegas USA
Here is the scoop, I'm looking for stock A15 pistons with 10cc dish or less, I think the correct part number 12010-H9704. Motor is currently standard bore. Basically I'm looking for a 10-1 compression ratio, will be using the GX head off my A12 and a GX head gasket ...if I can find the pistons................otherwise it's likely time for forged pistons.
I saw Stewart Wilkins has some on their site (inquired as to specs). PJZ has some used forged pistons but I'm trying to avoid machine shop cost.
Tom
Posted on: 2012/1/24 2:47
Re: Source for stock A15 pistons with 10cc or less dish??
From sydney.nsw
got some in a15 piston & rings .o4o(1mm) oversize with 12cc dish. only problem in sydney aust.
Posted on: 2012/1/24 3:14
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Quite a regular
Are those std B-210 Slugs ?
What years are they found in ?
I'm 4 Time Zones away instead of 12
Posted on: 2012/1/24 4:36
From sydney.nsw
they are a std replacement a15 cast pistons/rings with 12cc dish.same comp height/same pin size/same everything. have used 100's of them all good,also can make up full rebuild kits,pistons/rings/cr,mains,cam bearings/gaskets/timing chain,tensioner.(performance bits also available)to suit your sizes you need. cheers
Posted on: 2012/1/24 4:44
When I checked abour four years ago, Wiseco would make custom cast (not forged) pistons for $100/each. Any bore, pin height you want.
Nissan lists 12010-H9704 for $55/each in their 2010 catalog.
Posted on: 2012/1/24 5:45
From Las Vegas USA
I can find stock pistons but they are all 12cc dish, which if I go up to 78mm would get the compression to 9.91-1 which would be close enough. I actually ordered a couple from various sources ($10 close outs) but to no avail.
I tried the part numbers for 210 and 310. Basically I'm trying to do this on my usual uber-cheap budget. If I just go as is compression will be 9.37-1,realistically going to 10-1 will probably only bring about 4-5hp but the goal is 100 RWHP (current A12 is about 80).
Of course I should stop dorking around and attempt build a proper motor that is in the 120 RWHP range. Using the cylinder head on the A12 would keep the cost down, maybe as low as $1200-1500......proper pistons being the bulk of it.
Tom
Posted on: 2012/1/25 2:19
From SoCal
I understand that the GA16DE piston has been used in A15s with the downside being the need to surface the block. They seem to be cheaper and more available for stock-type cast. Thoughts?
http://www.totopiston.co.jp/cat/piston/pist-ni.html
Posted on: 2012/1/25 2:48
1969 MG Midget, A15/60A
From Las Vegas USA
The GA16 pistons are very close but rather than resurface the block I think it would be better to just bite the bullet and buy parts that fit.
Tom
Posted on: 2012/1/25 4:51
